B Tables Used by the Address Book System
This appendix contains the following topics:
The Address Book system uses tables to store both address book and batch processing information.
B.1 Address Book Tables
This table lists the tables used by the Address Book system:
Table Description
Address Book Master (F0101) Stores names, address numbers, search types, and address book category code information for an individual or company that is assigned an address book number.
Address Book - Who's Who (F0111) Stores names, address book information, and who's who category code information for individuals who are associated with a particular address book number. Also, the stored information includes the fields that need to be protected for data privacy.
Related Person (F01112) Stores names, personal information, and related- person category code information for individuals who are related to a who's who entry.
Address Book - Phone Numbers (F0115) Stores area codes, phone numbers, and types of phones. Also, the stored information includes the fields that need to be protected for data privacy.
Electronic Address (F01151) Stores E-mail and uniform resource locator (URL) addresses associated with a who's who entry.
Address by Date (F0116) Stores addresses, address lines, postal codes, and effective dates for address book numbers. Also, the stored information includes the fields that need to be protected for data privacy.
Postal Codes (F0117) Stores the city, state, county, country, and optionally, a second postal code, bulk mailing center and carrier route for postal codes that you enter.
Alternate Address (F01161) Stores addresses, address lines, postal codes, and effective dates for who's who and contact entries.
Address Organization Structure Master (F0150) Stores parent numbers, child numbers, address numbers, and structure types.
Enhanced Parent Child (F01501) Stores parent numbers and who's who child numbers.
Country Constants Master File (F0070) Stores country-specific address-book formats for international mailing labels.
AB Word Search Master (F01815) Stores words that are referenced when you search for a name.
Supplemental Database - Core (F01090)
Supplemental Database - Code (F01092)
Supplemental Database - Narrative (F01093)
Stores user-defined information, such as textual and statistical information.
Address Book Master Audit Log (F0101A) Stores a record of changes to existing address book records and new address book records that have been entered.
Address Book Data Permissions List Definitions (F01138) Stores the permission list definitions to be used for Address Book Data Privacy. The stored information includes the fields that should be protected for data privacy.
Postal Code Address (F0118) Stores the address associated with a specific postal code.
Activity Master (F01301) Stores the activities and tasks that are part of the Foundation Calendar module.
Activity Master Work Table (F01301W) Stores the activities and task records including the recurrence records that are generated when a user inquires on an activity.
Activity-Deleted IDs for Sync (F01302) Stores the records that are deleted in disconnected mode.
Calendar Master (F01311) Stores the calendar record and related properties for all calendars created in the Foundation Calendar module.
Recurrence Master (F01321) Stores the recurrence patterns for activities and tasks.
Recurrence Exclusion (F01331) Stores the exclusions for recurrences that are set up for an activity or task.
Action Plan (F01401) Stores the grouping of activity templates (that is, pseudo activities) that can later be used to create real activities.
Action Plan Activity (F01411) Stores the activity templates that are available to be associated with action plans.
Contacts Subscription Table (F011901) Stores the contacts for which a user has requested synchronization between the JD Edwards EnterpriseOne server and the Personal Information Manager.
Supplier Master (F0401) Stores supplier specific information.
Customer Master (F03012) Stores customer specific information.
B.2 Address Book Tables for Batch Processing
This table lists the tables used by the Address Book system for batch processing:
Table Description
Address Book - Interoperability (F0101Z2) Stores records that originate from an outside (third-party) source until they become JD Edwards EnterpriseOne address book records.
Customer Master LOB-Batch Table (F03012Z1) Stores records that originate from an outside (third-party) source until they become JD Edwards EnterpriseOne customer master records.
Supplier Master - Batch Upload (F0401Z1) Stores records that originate from an outside (third-party) source until they become JD Edwards EnterpriseOne supplier master records.
Batch Who's Who Information (F0111Z1) Stores who's who (contact) records that originate from an outside source until they become JD Edwards EnterpriseOne who's who entries.
Batch - Related Person (F01112Z1) Stores related person records that originate from an outside source until they become JD Edwards EnterpriseOne related person entries for a who's who entry.
Phones-Interoperability (F0115Z1) Stores phone numbers information for contacts.
Batch - Electronic Address (F01151Z1) Stores E-mail and URL records that originate from an outside source until they become JD Edwards EnterpriseOne electronic address records.
Batch - Alternative Address (F01161Z1) Stores alternative address records that originate from an outside source until they become JD Edwards EnterpriseOne alternative address records.
