| JD Edwards EnterpriseOne Applications Interoperability Fundamentals Implementation Guide Release 9.1 Part Number E15081-03 |
PDF · Mobi · ePub |
This chapter contains the following topics:
Section 10.1, "Processing Outbound Interoperability for Shop Floor Management"
Section 10.2, "Processing Inbound Interoperability for Shop Floor Management"
Section 10.3, "Reviewing and Revising Interoperability Transactions for Shop Floor Management"
Section 10.4, "Purging Interoperability Transactions for Shop Floor Management"
This section provides an overview of outbound interoperability for Shop Floor Management, lists a prerequisite, and discusses how to:
Set selected processing options for originating programs.
Set selected additional processing options for Hours and Quantities Update (R31422).
Set selected additional processing options for Work Order Completions (P31114).
You might need to send to another system transactions that you create or change in Shop Floor Management. For example, if the organization uses handheld scanning devices, you can use interoperability transactions to update the database used by the scanning devices.
This table lists the JD Edwards EnterpriseOne Shop Floor Management programs from which you can send transactions to an external system:
To create outbound transactions, specify the appropriate transaction type in the processing options for these programs. The system places a copy of the transaction in the interface table for that type of transaction. The system uses the Flat File Cross-Reference Table (F47001) to identify the interface tables to populate based on the transaction type you specify in the processing options.
The system creates the outbound transaction in EDI format. External systems can process the transactions using standard EDI processing, including extraction.
You run outbound extraction programs to retrieve data from the outbound transaction tables and create a flat file if one does not exist, or to append to an existing flat file. Every field is written from the EDI interface tables to the flat file.
To process outbound interoperability for work order parts detail transactions:
Specify a transaction type in the processing options of the Work Order Parts Detail program (P17730).
Enter or change a record in this originating program.
The system calls a master business function that writes records to the Outbound Work Order Header table (F4801Z1) and the Outbound Work Order Parts List table (F3111Z1). The same master business function calls a special subsystem API that sends a message to the subsystem kernel running on the server. The subsystem kernel adds a record to the Subsystem Job Master table (F986113).
Create a custom UBE or function to process the data from the F4801Z1 and F3111Z1 tables in such a way that it can be used by the external system.
Use the Data Export Controls program (P0047) to specify the custom UBE or function for the transaction type you specified in the processing options of the originating program.
The system stores this information in the Data Export Control table (F0047).
Run the Interoperability Generic Outbound Subsystem UBE program (R00460).
The Interoperability Generic Outbound Subsystem UBE program fetches the F986113 record and retrieves the name and version of the custom UBE from the F0047 table. The Interoperability Generic Outbound Subsystem UBE program passes information about the order to the custom UBE. The custom UBE then retrieves the records from the F4801Z1 and F3111Z1A tables and processes that information.
Define the data export controls for the type of outbound transaction. The system uses data export controls to determine the batch programs or business processes that third parties supply for use in processing transactions.
This section lists only the processing options that are specific to outbound interoperability. These processing options are used for the following programs:
Specify the transaction type for the interoperability transaction. If you leave this processing option blank, the outbound interoperability is not performed.
Specify whether the system creates a record of the image before it was changed, in addition to a record of the transaction after the change. The system creates these records in the unedited transaction table when outbound interoperability processing is enabled. Values are:
Blank: Write the record only after it has been changed; do not write a before image record.
1: Write two records: one before the image is changed and one after the image is changed.
The Hours and Quantities Update program has a unique processing option in addition to the interoperability processing options that are common to all of the originating programs.
Enter 1 to call the subsystem after the Hours and Quantities Update program (P31422) successfully processes the outbound transactions.
The Work Order Completions program has a unique processing option in addition to the interoperability processing options that are common to all of the originating programs.
Enter 1 to call the subsystem after the Work Order Completions program (P31114) has successfully processed an outbound transaction.
This section provides an overview of inbound interoperability for Shop Floor Management, lists prerequisites, and discusses how to:
Set processing options for Inbound Hours and Quantity Processor (R31122Z1I).
Set processing options for Inbound Inventory Issues Processor (R31113Z1I).
Set processing options for Inbound Completion Processor (R31114Z1I).
Set processing options for Inbound Super Backflush Processor (R31123Z1I).
Setting processing options for Inbound Kanban Transaction (R30161Z1I).
Run the inbound processing programs.
In an inbound transaction, you accept data from another system into this system.
JD Edwards EnterpriseOne Shop Floor Management provides these versions of the Inbound Flat File Conversion program (R47002C):
Inbound Backflush Flat File Conversion.
Inbound Completion Flat File Conversion.
Inbound Issues Flat File Conversion.
Inbound Work Order Flat File Conversion.
The interoperability interface table for hours and quantities inbound transactions is the Work Order Time Transactions Unedited Transaction table (F31122Z1).
You run the Inbound Hours and Quantity Processor program (R31122Z1I) to copy the information from the F31122Z1 table to the related application tables.
The interoperability interface table for inventory issues inbound transactions is the Outbound Work Order Parts List table (F3111Z1).
You run the Inbound Inventory Issues Processor program (R31113Z1I) to copy the information from the F3111Z1 table to the related application tables.
The interoperability interface table for completion inbound transactions is the Outbound Work Order Header table (F4801Z1).
You run the Inbound Completion Processor program (R31114Z1I) to copy the information from the F4801Z1 table to the related application tables.
The interoperability interface table for completion inbound transactions is the Outbound Work Order Routings table (F3112Z1).
You run the Inbound Super Backflush Processor program (R31123Z1I) to copy the information from the F3112Z1 table to the related application tables.
Before you complete the tasks in this section:
Set up flat file cross-references.
Run the Inbound Flat File Conversion program (R47002C).
See Running the Inbound Flat File Conversion Program (R47002C).
Processing options enable you to specify the default processing for programs and reports.
Enter a version of hours and quantities. If you leave this processing option blank, the system uses ZJDE0001.
Specify the type of processing for an event. If you leave this processing option blank, the system prints all records.
Enter a version of work order inventory issues. If you leave this processing option blank, the system uses ZJDE0001.
Enter a version of inventory completions.
The system has versions that begin with XJDE or ZJDE. If you leave this processing option blank, the system uses ZJDE0001.
Enter a version of work order super backflush. If you leave this processing option blank, the system uses ZJDE0001.
Enter a version of the Kanban Processing program. If you leave this processing option blank, the system uses ZJDE0001.
Enter 1 to print only records that are not processed successfully. If you leave this processing option blank, all records are printed.
To receive hours and quantity inbound transactions, select Shop Floor Management Interoperability (G31311), Inbound Hours and Quantity Processor.
To receive inventory issues inbound transactions, select Shop Floor Management Interoperability (G31311), Inbound Inventory Issues Processor.
To receive completion inbound transactions, select Shop Floor Management Interoperability (G31311), Inbound Completion Processor.
To receive super backflush inbound transactions, select Shop Floor Management Interoperability (G31311), Inbound Super Backflush Processor.
To receive kanban inbound transactions, select Shop Floor Management Interoperability (G31311), Inbound Kanban Transaction.
This section provides an overview of reviewing and revising interoperability transactions for Shop Floor Management, lists the forms used to review and revise interoperability transactions for Shop Floor Management, and discusses how to:
Set processing options for Inbound Work Order Inquiry (P4801Z1).
Set processing options for Inbound Hours and Quantity Inquiry (P31122Z1).
Set processing options for Inbound Inventory Issues Inquiry (P3111Z1).
Set processing options for Inbound Super Backflush Inquiry (P3112Z1).
Set processing options for Kanban Transactions Revisions (P30161Z1).
Running one of the transaction processes, such as the Inbound Work Order Inquiry (P4801Z1), often identifies one or more inbound transactions that contain invalid transactions. For example, a work order might have an invalid item number. In that case, the program cannot add that work order to the Work Order Master table (F4801). Instead, the program sends an error message to the Employee Work Center program (P012501), which indicates the transaction number for the transaction in error.
Use the inbound inquiry programs to review and revise inbound transactions, as well as to add, change, or delete transactions that contain errors. Then run the transaction process again. Continue to make corrections and rerun the transaction process until the program runs without errors.
See "Running Inquiries and Revising EDI Documents" in the JD Edwards EnterpriseOne Applications Data Interface for Electronic Data Interchange Implementation Guide.
Specify the type of processing for an event. Values are:
1: View unprocessed records
2: View records processed successfully
3: View records processed unsuccessfully
If you leave this processing option blank, the system uses View unprocessed records as the default.
Specify whether the transaction is inbound or outbound. Values are:
1: Inbound
2: Outbound
If you leave this processing option blank, the system uses Outbound as the default.
Enter 1 or leave this processing option blank to display the Work Order Revisions form. Enter 2 to display the Completion Revisions form.
Specify the type of transaction for the work order. If you leave this processing option blank, the system uses JDEHO.
Specify the type of transaction for the work order parts list. If you leave this processing option blank, the system uses JDEPL.
Specify the type of transaction for the work order routings. If you leave this processing option blank, the system uses JDERTG.
Specify the program to process the transactions. If you leave this processing option blank, the system uses R31122Z1I.
Enter a version of Inbound UBE. If you leave this processing option blank, the system uses XJDE0002.
Specify whether the transaction is inbound or outbound. If you leave this processing option blank, the system uses Inbound as the default. Values are:
1: Inbound
2: Outbound
Specify the transaction for the work order. If you leave this processing option blank, the system uses JDEHO.
Specify the object member to be sent out on a PTF request. If you leave this processing option blank, the system uses R31122Z1I as the default.
Specify the type of processing for an event. If you leave this processing option blank, the system uses View unprocessed records as the default. Values are:
1: Inbound
2: Outbound
Specify a specific type of transaction for the work order. If you leave this processing option blank, the system uses JDEII.
Specify the object member to be sent out on a PTF request. If you leave this processing option blank, the system uses R31113Z1I.
If you leave this processing option blank, the system uses inbound as the default. Values are:
1: Inbound
2: Outbound
Specify the transaction for the work order. If you leave this processing option blank, the system uses JDESBF.
Specify the object member to be sent out on a PTF request. If you leave this processing option blank, the system uses R31123Z1I.
If you leave this processing option blank, the system uses ZJDE0001 (inbound records) as the default.
Specify a value to indicate how the system displays the records. Values are:
1: The system displays the unprocessed records.
2: The system displays all successfully processed records.
3: The system displays all unsuccessfully processed records.
Specify a code that indicates whether the transaction is inbound or outbound. Values are:
1: Inbound Records
2: Outbound Records
Enter the transaction type for new Kanban transactions. If you leave this processing option blank, the system uses JDEKNB.
Enter the name of the inbound subsystem UBE to call to process inbound transactions. If you leave this processing option blank, the system uses R30161Z1I.
Specify a version of the inbound subsystem UBE. If you leave this processing option blank, the system uses XJDE0001.
This section provides an overview of purging interoperability transactions and discusses how to purge interoperability transactions.
When data becomes obsolete or you need more disk space, you can use purge programs to remove data from interface tables.
The interoperability menu contains options for purging transactions. Use one of these purge programs to remove data from the corresponding interface tables:
For records in the Processing Log table (F0046) that are marked as processed, the program purges the associated transactions in the corresponding interoperability tables, as well as the records in the F0046 table. If the records in the F0046 table are not marked as processed, the program does not purge any records.
When you purge cycle count transactions, you can set the processing option to print only the records that are in error. Otherwise, the program prints all records that are deleted.
To purge inbound or outbound work order transactions, select Shop Floor Management Interoperability (G31311), Interoperability Work Order Purge.
To purge inbound hours and quantity transactions, select Shop Floor Management Interoperability (G31311), Inbound Hours and Quantity Purge.
To purge inbound inventory issues transactions, select Shop Floor Management Interoperability (G31311), Inbound Inventory Issues Purge.
To purge inbound completion transactions, select Shop Floor Management Interoperability (G31311), Inbound Completion Purge.
To purge inbound super backflush transactions, select Shop Floor Management Interoperability (G31311), Inbound Super Backflush Purge.
To purge inbound kanban transactions, select Shop Floor Management Interoperability (G31311), Inbound Kanban Purge.
