This chapter contains the following topics:
Section 5.1, "Understanding the Configured Item Revisions Program"
Section 5.6, "Assigning Common Attributes to Configured Items"
Section 5.7, "Entering Nonstandard Components and Price Adjustments"
Section 5.8, "Correcting Error Messages for Configured Items"
After you set up the segments, cross-segment editing rules, assembly inclusion rules, configured tables, and media object attachments for a configured item, you can enter orders for the configured item.
Use the Configured Item Revisions program (P3210) to designate the features and options of a configured item on an order. You use Sales Order Entry (P4210), Purchase Orders (P4310), and Manufacturing Work Order Processing (P48013) to enter an order for a configured item. As with any order, you enter information in the order header and order detail areas. After you enter the item number and press Tab, or move off that order line, the system automatically calls and displays the Configure Item form. This process occurs because the item number of the configured item is coded as a C stocking type in the Item Master. Thus, the system is programmed to automatically call the Configured Item Revisions program so that the configured item can be defined for the order.
The processing options for the Configured Item Revisions program control the display of information on the Configure Item form. Within the order entry process, you use dynamic configuration entry or the validate configuration feature. The system uses the validate configuration feature for non-dynamic and single pass rules processing (Release 9.1 Update).
The Message Center displays configuration specific information such as the configuration state, hot spot values, weight, and error messages. The configuration state indicates if the configuration is valid, invalid, or if validation is required. You can display up to ten different hot spot values on the Configure Item form. The hot spots that appear after successful rules calculation are set by the processing options. To review detailed error messages, you click the error link.
The JD Edwards EnterpriseOne Configurator system also calculates the weight of a configured item based on the multilevel items that make up the parent item. You can select to designate a base weight for the configured item. The weight is calculated as the item is entered within order entry. You must enter the same weight units of measure for each segment that makes up the configured parent item. Weight is calculated by using P rule components only.
The Item Filter field gives you access to the configured items and associated segments at various levels in the parent configured item when you click the item number that is in the Item Filter field.
The segments that represent the features and options of the configured item that is highlighted appear. Several fields appear to further define the segments. You enter a value for each segment in the Select Answer or Enter Answer field. The Select Answer field gives you access to any user-defined codes (UDCs) that might be defined for the segment. You enter a value in the Enter Answer field if no UDC is attached to the segment. The system edits each segment value using UDC tables, ranges, and numeric specifications.
The segment numbers and UDCs display on the Configure Item form at order entry. Segment numbers display in the Segment Number field. You use the UDC Display processing option on the Processing tab of the Configured Item Revisions program to specify whether a segment answer in the Select Answer field displays as a code or description from the associated UDC. Once the processing option is set, you can select segment answers by code or description in the Select Answer field. (Release 9.1 Update)
Many line items on configured orders can share a common attribute. A common attribute that is used in a configured item can be set at the start of an order. The chosen value can be applied as the default to each subsequent line item that is entered. This feature is useful in a high attribute selection and high line item order environment. The feature can save time and labor during the order entry process. It also prevents unnecessary errors during order entry. The common attribute can then be revised in the middle of order entry to accommodate changes in customer specifications.
Processing options control the prompting for common attributes. The common attribute can be set to automatically appear at the beginning of order entry (between the order form and the Configure Item form). You can also access the Configurator Common Attributes form from the Configure Item form during configuration definition.
For example, the furniture industry can use common attributes to configure a sofa. In a configuration for a sofa, a common attribute might be Color. The Color common attribute is associated with the segments for the sofa frame, bottom sofa cushions, sofa arm covers, and decorative pillows. After the customer picks a color, you can enter that value in the Attribute field on the Configurator Common Attributes form. The color is then applied as the answer to all of the segments that are associated with that particular common attribute.
Media object attachments display in the lower region of the Configure Item form if the processing options are set and there is a media object attached to the configured item. You can enter nonstandard components and price adjustments to the configured item. You can also access configured item inventory and history information from the Configure Item form.
The Configured String History program (P3296) locates previously ordered configurations at any level of a configured item. The history includes information about customers, orders, order types, and branch/plant.
The Configured Item Inventory Search program (P3220) locates inventory that can be used to fulfill the order for the configured item.
When a user enters an order for a configured item, the Sales Order Entry (P4210), Purchase Order Entry (P4310), and Manufacturing Work Order Processing (P48013) programs call the Configured Item Revisions program (P3210). You use the Configure Item form (W3210B) of the Configured Item Revisions program to configure an item and perform rules processing.
During order entry, rules for configured items can be processed dynamically or you can select to use the validate configuration feature. The system uses the validate configuration feature for non-dynamic and single pass rules processing (Release 9.1 Update). Non-dynamic, dynamic, and single pass rules processing is enabled or disabled at the item level on the Configured Item Information form (W3291A) (Release 9.1 Update). Child-configured items inherit the rules processing setting of the parent-configured item (Release 9.1 Update).
Regardless of whether non-dynamic or dynamic configuration is enabled, the system processes only the rules associated with a changed segment (Release 9.1 Update). Each time a segment answer is changed and is valid; all of the configuration rules that reference the segment are marked for processing. The rules are then processed based on the setting in the Rules Processing option (Release 9.1 Update).
When dynamic configuration entry is enabled, the system dynamically validates the item configuration as the order is entered. Any time that a segment answer is changed, the entire configuration reflects the impact of the new value. When a segment answer is changed, all allowed values for other segments are updated to include only valid values based on the processed cross-segment editing rules. If there are no valid values left for a segment after the cross-segment editing rules are processed, then the system removes the segment from the configuration.
The processed assembly inclusion rules update components, price adjustments, cost adjustments, and hot spots.
Dynamic configuration entry provides immediate feedback as the product is configured and lessens the possibility of selecting invalid segment values. The configuration is in a state that can immediately be committed to an order.
When non-dynamic configuration entry is enabled, the Validate Configuration button appears on the Configure Item form (Release 9.1 Update). To enter an order for a configured item, you enter values for segments and click the Validate Configuration button. The system validates the item configuration by processing the rules associated with the changed segments.
Single pass processing provides an alternative method to non-dynamic and dynamic configuration for configurator rules processing. Single pass processing may be used as a migration path when upgrading complex rule sets from a release prior to JD Edwards EnterpriseOne 9.0. (Release 9.1 Update)
Note: Single pass processing is not intended to be a permanent solution for recursive assembly inclusion rule setup. Single pass processing may be used in the short term when the size and complexity of rules makes revision of assembly inclusion rules prohibitive when upgrading to JD Edwards EnterpriseOne release 9.0 or later. However, you should evaluate assembly inclusion rules and revise them so that you can realize the advantages of dynamic configurator. (Release 9.1 Update) |
When single pass processing is enabled, the system processes all rules when you change any segment and click the Validate Configuration button. The system processes all assembly inclusion rules and cross-segment editing rules only once in top down order. The segment value is set based on the last valid rule that is processed. (Release 9.1 Update)
Note: Single pass processing may produce different results from either non-dynamic or dynamic rules processing when configuring an item depending upon assembly inclusion rule setup. (Release 9.1 Update) |
Using the Validate Configuration button with non-dynamic or single pass rules processing provides visibility to cross-segment editing rule error messages (Release 9.1 Update). Viewing the error messages gives you the opportunity to learn the configuration of the configured item. You can also provide an explanation to the consumer as to why their segment selections do not generate a valid configuration.
Click the Add to Order button to accept the configuration if no cross-segment editing rule errors exist.
You enter an order for a configured item once the Configured Item form is rendered and the grid is loaded. As you enter an order, the system verifies JD Edwards EnterpriseOne Configurator processes level by level in this order:
Change segment values or click the Add to Order button to accept all default values.
If non-dynamic or dynamic rules processing is enabled, each time a segment answer is changed and is valid; all of the configuration rules that reference the segment are marked for processing. The rules are then processed based on the dynamic configuration entry setting. (Release 9.1 Update)
If single pass processing is enabled, the system marks all segments as changed and marks all assembly inclusion and cross-segment editing rules for processing. The system processes all rules only once in top down order. (Release 9.1 Update)
Validate segment agreement.
System processing includes UDC validation, range checking, alpha versus numeric checking, length checking, and required versus optional checking.
Process assembly inclusion rules.
For non-dynamic and dynamic, the system processes rules related to changed segments only. For single pass, the system processes rules for all segments. (Release 9.1 Update)
Process C assembly inclusion rules and update C segments.
The system processes C rules first because the calculated segment answer might be required to validate the configuration. The calculated segment answer might also be needed to perform additional calculations for the configured item.
Process P assembly inclusion rules.
Process Q assembly inclusion rules.
The system processes Q assembly inclusion rules and stores the components in the Configurator Component table (F3215). The components are used by Sales Quotes (P4210) to establish cost and Order Processing (R31410) to create the parts list and establish cost.
Process R assembly inclusion rules.
The system processes R assembly inclusion rules and stores the routings in the Configurator Routings table (F3212). The routings are used by Sales Quotes (P4210) to establish cost and Order Processing (R31410) to create the routing and establish costs.
Process X assembly inclusion rules.
Process H assembly inclusion rules.
Process cross-segment editing rules.
If dynamic configuration entry is disabled, the system displays any error messages.
If dynamic configuration entry is enabled, the system:
Updates all allowed values for other segments to include only valid values.
Sets the valid value if there is only one allowed valid value for a segment.
Removes the segment from the configuration if there are no valid values left for a segment.
See Cross-Segment Editing Rules Editing Process for Dynamic Configuration.
Enable the Add to Order button if no cross-segment editing errors exist.
Click the Add to Order button.
Note: The JD Edwards EnterpriseOne Configurator system supports upward and downward referencing within cross-segment editing and assembly inclusion rules for non-dynamic and dynamic rules processing. Upward or downward referencing for non-dynamic and dynamic rules processing has no limitations.The JD Edwards EnterpriseOne Configurator system supports upward referencing only within cross-segment editing and assembly inclusion rules for single pass rules processing. Single pass rules processing does not support downward referencing. Upward referencing for single pass rules processing has no limitations. (Release 9.1 Update) |
All components from both P and Q assembly inclusion rules are stored in the F3215 table. The routings, output of the R assembly inclusion rules, are stored in the F3212 table. When the Order Processing program (R31410) runs, the parts list and routing are retrieved from the F3215 and F3212 tables and passed back to the Parts List master business function (MBF) and the Routings MBF. Thus, the R31410 does not process configured item rules.
When entering orders for configured items, there are a few circumstances that can cause the Configured Item Revisions program (P3210) to display errors.
First, when a segment is not attached to a UDC table, it is possible to free-form type into the segment answer field. If there is a range of values assigned to that segment, then a violation creates an error.
Second, again assuming that a segment is not attached to a UDC, a cross-segment editing rule can be created that generates an error when violated.
Finally, although perhaps the first to be encountered, multiple errors can be present when first entering the Configured Item Revisions program if the default segment values create an error state.
To minimize error states, attach UDCs to segments when possible. Also, review the default segment answers for a configured item to ensure that the default values represent a valid configuration.
When setting up a configured item, you can design the segment questions in such a way as to avoid errors. For instance, ask the most important questions first. Thus the consumer will not have visibility to choices that make the configuration invalid. For example, the first question should be whether the consumer wants a car or truck and not the color of the vehicle.
You can also use warning messages. Warning messages provide information regarding a choice that may or may not work in the configuration. The system does not remove the selected value but the warning gives the user the opportunity to make a different selection.
When you enter an order for a configured item and trigger validation of the configuration, the system calculates price and cost adjustments. During configuration validation, the JD Edwards EnterpriseOne Configurator system reads the based-on date code from the Configured Item Information (F3290) table.
The JD Edwards EnterpriseOne Configurator system then retrieves the date corresponding to the based-on date code of the parent configured item from the JD Edwards EnterpriseOne Sales Order Management, JD Edwards EnterpriseOne Work Order Processing, or JD Edwards EnterpriseOne Procurement systems for the order type of the original order. The value is retrieved and stored in the configurator data cache for use in processing. This date is the X rule based-on date.
The JD Edwards EnterpriseOne Configurator system retrieves the X rule based-on date from the configurator data cache and validates each X rule setup in the Assembly Inclusion Rules (F3293) table. The system compares the X rule based-on date to the effective from and through dates of the X assembly inclusion rules.
If valid X assembly inclusion rules are found, the system applies the rules to calculate the price and cost of the configured item order. Once the validated X rules are processed, the system inserts a new record or updates an existing record in the Sales Order Detail File (F4211), Work Order Master (F4801), or Purchase Order Detail (F4311) table.
For example, a configured item is setup to use the order date as the sales order based-on date and requested date as the work order based-on date. If a sales order is entered for the item on August 15th, with a requested date of October 15th, the system searches for X assembly inclusion rules that are effective on August 15th. Valid X rules apply price adjustments to the sales order. If a work order is entered for the configured item, October 15th is used to validate X rules and apply cost adjustments to the work order.
If the X rule based-on date cannot be retrieved or a blank date is returned, the system uses the requested date to process the X assembly inclusion rules. The based-on date setting of the parent configured item is inherited by the child configured items.
The based-on effectivity date functionality in the JD Edwards EnterpriseOne Configurator system is similar to the functionality in JD Edwards EnterpriseOne Advanced Pricing. JD Edwards EnterpriseOne Advanced Pricing enables the user to specify one or many dates, such as order and required, to use to include price adjustments. The based-on date code of Price Effective Date is used to sync with JD Edwards EnterpriseOne Advanced Pricing so that the system uses the same date as JD Edwards EnterpriseOne Advanced Pricing when validating X rules. This applies to both sales and purchase orders.
During sales order entry, the Price Effective Date field may display a price but you can override the value. For purchase orders, only cost adjustments from X rules are applied to the order.
See Understanding Configured Item Pricing and Costing Using Based-on Effectivity Dates.
Before you complete the tasks in this section:
Set the Sales Order Entry (P4210) processing option for the work order line type to create work orders, or define the W line type in the branch/plant record for each configured item.
If you leave the processing option blank, the system supplies the line type from the branch/plant.
Set the processing options for the versions of the Sales Order Entry program (P4210) that you will use for sales quotes, transfer order entry, and direct ship order entry for configured items.
Set the processing options for the version of the Purchase Orders program (P4310) version that you will use for configured items.
Set the processing options for the version of the Work Order Entry program (P48013) that you will use for configured items.
This section provides an overview of order revisions for configured items and discusses how to:
Set processing options for Configured Item Revisions (P3210).
Enter orders for configured items.
Enter an order based on a previously ordered configured item.
If a customer calls and needs to add or change information on an order, you can revise the order for a configured item. The JD Edwards EnterpriseOne Configurator system also enables you to revise the work order for a configured item.
This table describes types of revisions that could occur:
Revision | Description |
Changing quantity | The system changes the order quantity and, if you set a processing option, also changes the quantity on the work order. |
Changing segment value | The system changes the segment values on the order and, if you set a processing option, also changes the segment values on the work order. Changing a segment value might produce new configured components or prices. You might need to run work order processing again. |
Changing pick date | The system recalculates work order start dates, based on lead times. When you change the pick date for an order, the system supports multilevel back-scheduling for the associated work orders. |
Changing order dates | The system recalculates the X assembly inclusion rule price and cost adjustments when the dates on an existing order are changed. |
Changing an order that generated a purchase order | The system changes or cancels the purchase order for the component of a configured item when the configuration is changed. |
Purging order lines | The system purges order lines for components that are no longer required after the change. |
Calculating new order line numbers | The system uses the base line number for the configured item and increments by .001 for each configured component. |
Canceling an order | When you cancel an order for a configured item, the system cancels the subassemblies and lower-level segments for the item. |
Reassigning work order numbers | The system retains work orders that are still valid after a revision. The system might cancel work orders that are no longer required after the change by changing the status code of the work order. |
Changing the work order cutoff status code | When you work with the Work Order Entry program (P48013), the system changes the work order if the work order status is less than the cutoff status. If the begin status code is not blank, the system updates the status to what is defined in the processing option.
If the work order status is greater than or equal to the cutoff status, the system does not change the work order. If the change status code is not blank, the work order status is updated to what you defined in the processing option. |
Placing the order on hold (hold status code) | If the work order status in the Work Order Entry program is less than the cutoff status and the hold status code is not blank, the system updates the work order status to the hold status code that is defined in the processing option.
If the work order status is greater than or equal to the cutoff status, the system does not update the work order. |
Canceling the order (cancel status code) | If the work order status is less than the cutoff status and the cancel status code is not blank, the Work Order Entry program updates the work order status to the cancel status code that is defined in the processing option.
Creating new work orders | The program creates a new work order, if required, after the change. |
Processing options enable you to specify the default processing for programs and reports.
These processing options control the default information that the system uses when you run the Configured Item Revisions program.
Specify the default action that is preselected in the Actions drop-down list on the Configure Item form. Values are:
1: Edit Item/Cost
2: Common Attributes
3: Configured Item Inventory
4: Configured Item History
Specify whether configured parts print on sales orders and work orders. This processing option is used in the Pick Slip, Invoice Print, Bill of Lading, and Print Parts List programs. Values are:
Y: Print on the sales and work order. You can also use 1.
N: Do not print on the sales and work order. You can also use 0.
2: Sales order only.
3: Work order only.
Specify how the system processes lines on a transaction. The line type controls the systems with which the transaction interacts (JD Edwards EnterpriseOne General Ledger from Oracle, JD Edwards EnterpriseOne Job Cost from Oracle, JD Edwards EnterpriseOne Accounts Payable from Oracle, JD Edwards EnterpriseOne Accounts Receivable from Oracle, and JD Edwards EnterpriseOne Inventory Management). It also specifies the conditions under which a line prints on reports and is included in calculations.
This processing option uses line type to group X rule prices. Values are:
S: Stock item
J: Job cost
N: Non-stock item
F: Freight
T: Text information
M: Miscellaneous charges and credits
W: Work order
These processing options specify the hot spots that display in the Message Center on the Configure Item form.
Specify a user-defined code from UDC 32/HS that indicates the type of information that appears for a hot spot, for example, the domestic price, foreign price, or weight.
This processing option specifies how the system processes orders with allowed lot status.
Specify the lot status group that you want the system to use when determining whether to process an item with a non-blank lot status. If the non-blank lot status codes exist in the Allowed Lot Status table (F41081), then the system treats the lot status codes as blank and the on hold item can continue through the sales order process.
These processing options control how the system processes and displays values.
Specify whether to display media objects on the Configure Item form. This option controls context-sensitive display of media objects that are related to items, segments, and user-defined code values. Values are:
1: Display.
Blank: Do not display.
Specify the order in which media objects appear on the Configured Item Revisions form if more than one media object type is attached to a configured item or segment. If more than one media object of the same type exists, the first attached object in the selected type will be displayed. Values are:
1: Text
2: Image
3: OLE
Blank: Image
Specify whether the system displays common attributes among configured items. Values are:
1: Without automatic prompt.
2: With automatic prompt.
Blank: Do not display common attributes.
Specify whether to display common attributes that are specific to the configured item. Values are:
1: Display all common attributes.
Blank: Display only common attributes that are used in the configuration.
Specify whether to perform calculations using C rules for configured items upon entry. Values are:
Blank: Perform
1: Omit
Specify whether to substitute configured item text (which exists as a media object) or to append it. Values are:
Blank: Append
1: Substitute
Specify whether to display segment answers associated with a UDC as codes or descriptions on the Configured Item Specifications form. Values are:
1: Display UDC codes.
Blank: Display UDC descriptions.
These processing options specify the version that the Configured Item Revisions program uses when calling other programs.
Specify the version of the Transfer Orders program (P4210) that the system uses if any related transfer orders are created during configured-item order entry. Based on the needs of the customers, you can create multiple versions of this program.
Specify the version of the Purchase Order Entry program (P4310) that the system uses if any related purchase orders are created during configured-item order entry.
When you save an order for a parent configured item, the system uses this version to generate or update the purchase order for the component of a configured item whose transaction type is 4 (purchase order).
Access the Configure Item form.
Important: The Rules Processing option on the Configured Item Information form must be set to Non-Dynamic or Single Pass to disable dynamic configuration (Release 9.1 Update). |
Note: You cannot complete the order until all hard errors are corrected. |
Displays configuration specific information such as the configuration state, hot spot values, and error messages.
Select the item to display for a specific configured item in the assembly. If a specific configured item is not selected, all items will appear.
Select a value from the list of values if a user-defined code was set up for the segment.
Enter a value for each segment when the segment does not have a user-defined code attached.
Click to process the configured answers you enter. The validation uses the cross-segment editing rules to validate feature and option compatibility.
Click to restore all segment values to the default value entered during system setup.
Click to create an order for the configured items. This button is enabled if no errors occurred during the validation and the configuration is valid.
Select an option in the Actions drop-down list and click the Go To button.
Select to access the Edit Item/Price Cost form. You can review the multilevel structure of the configured item on the order in a navigation tree structure.
Items in the tree were added by either a P assembly inclusion rule or by using the Add Item option. Prices in the tree were added by an X assembly inclusion rule or by using the Add Price/Cost option. The button next to each line in the tree designates whether the line was system-generated from an assembly inclusion rule or user-added.
Select to access the Configurator Common Attributes form.
This option is hidden if no common attributes are associated with the configured item.
Select to access the Configured Item Inventory Search form.
Select to access the Configured Item History form.
Important: The Rules Processing option on the Configured Item Information form must be set to Dynamic to enable dynamic configuration (Release 9.1 Update). |
Note: The Validate Configuration button is not used during dynamic configuration entry. |
To enter an order based on a previously ordered configured item:
Select Configured Item History in the Actions drop-down list and click the Go To button.
Complete the search fields and click Find on the Configured Item History form.
Select a sales order and click Select.
The configuration information is brought back to the new order. The values in the Select Answer field change to those of the order that you selected on the Configured Item History form. You can revise the order or use it as it is.
Make any necessary changes on the Configure Item form.
Note: If dynamic configuration entry is disabled, click the Validate Configuration button. |
Click the Add to Order button if you do not receive any errors.
This section provides an overview of common attributes of configured items, lists a prerequisite, and discusses how to assign common attribute values.
To better organize the configured items and simplify configurations that are entered during order entry, you can assign common attributes to configured item segments. Common attributes are initially linked to a segment in the Configured Item Segments program (P3291). You assign common attribute values on the Configurator Common Attributes form.
Common attribute values operate as default answers for each configuration level. For example, a common attribute code that is defined as Color might have a value of Red. With common attributes activated, each configured level with the common attribute code of Color automatically returns the Red value.
You set a processing option to either view common attributes for all configured items or view them as they apply within the current configuration. Additionally, you can change common attribute values during order entry.
Even if you automatically display common attributes, you can access the Configurator Common Attributes form during order entry to change the value for all associated segments. On the Configurator Common Attributes form, when you click OK, the Configured Item Revisions form appears, and you can continue to enter the order.
You also can change a single segment value using the Select Answer field.
Set the Common Attribute Display and Common Attribute Display Scope processing options on the Configured Item Revisions program (P3210) to define the appearance of the Configurator Common Attributes form.
See Setting Processing Options for Configured Item Revisions (P3210).
Access the Configurator Common Attributes form.
Enter a code that specifies a common attribute. A common attribute is a trait or characteristic that is shared by several segments in a configured item. When you enter an attribute value for a common attribute during order entry, the system updates the Answer field for all segments that are associated with that common attribute.
Enter a value for the selected common attribute.
This section provides an overview of nonstandard components and price adjustments and discusses how to add nonstandard components and price adjustments.
When you need to add special parts or prices to further configure a configured item, you can enter nonstandard components and price adjustments. Entering nonstandard components and price adjustments enables you to configure the configured item without creating new assembly inclusion rules, tables, or smart parts.
Nonstandard components are priced according to the Kit/Configurator Pricing Method for the configured parent item. Price or cost adjustments are similar to the X assembly inclusion rules that are set up for the configured item. They affect only the sales order, not the work order.
Nonstandard components and price adjustments are added on the Edit Item/Price/Cost form. This form enables you to review all of the order components and prices before the line item is confirmed. Once an item or price/cost is entered, the tree display is refreshed by the system.
You can delete nonstandard components or price adjustments for the configured parent item. You cannot delete standard components and price adjustments. A nonstandard component or price adjustment can be distinguished from a standard component or price by the button that precedes it in the navigation tree on the Edit Item/Price/Cost form.
Note: On the Edit Item/Price/Cost form, items in the tree are added by the P assembly inclusion rule. Prices in the tree are added by an X assembly inclusion rule. The button next to each line in the tree designates whether the line was system-generated from an assembly inclusion rule or user-added. |
Access the Edit Item/Price/Cost form.
Figure 5-2 Edit Item/Price/Cost form (1 of 3)
Select the Add Item tab.
Figure 5-3 Edit Item/Price/Cost form: Add Item tab (2 of 3)
Enter a value from UDC 32/PF that indicates whether the system prints the configurator part on the sales order and work order. The system uses the value that you enter in this field to affect programs such as Print Pick Slips (R42520), Print Invoices (R42565), Bill of Lading (R42530), and parts list on Work Order Print (R31415). Values are:
0: Do not print the configurator part on the sales order or the work order.
1: Both the sales order and the work order.
3: Work order only.
Enter values in the fields on this tab and click the Add Item button to add the component.
Select the Add Price/Cost tab.
Figure 5-4 Edit Item/Price/Cost form: Add Price/Cost tab (3 of 3)
Enter the list or base price to be charged for one unit of this item. In sales order entry, all prices must be set up in the Item Base Price File table (F4106).
Enter the amount per unit, derived by dividing the total cost by the unit quantity.
Enter a UDC (32/PP) that indicates whether the price or cost of an add-on is included in the price or cost of the parent configured item. Values are:
0: Separate the price or cost of the add-on.
1: Include the price or cost of the add-on in the price or cost of the parent item. When you select this value, the extended price or cost is zero.
Enter values in the fields on this tab and click the Add Price/Cost button to add the price or cost.
Note: After you finish adding nonstandard components and price adjustments, click the Close button. If you do not receive any errors, click Add to Order on the Configure Item form. You cannot complete the order until you correct all hard errors. |
This section provides an overview of error messages for configured items and discusses how to correct error messages for configured items.
During the configuration process within order entry, the system verifies the segment values that you enter with the cross-segment editing rules and configured item segments. The system verifies that you have not entered any values that violate the editing rules. If a segment value violates an editing rule, either a hard or a soft error message appears.
Hard error messages indicate significant errors from cross-segment error checking. When you receive a hard error message, you cannot proceed with the order until you correct the error.
Soft error messages do not prevent you from completing the order, but they do provide error information. You can either correct the error or leave it as it is, and the order processes either way.
If the system finds errors in cross-segment editing rules, you receive notification that error messages exist during the dynamic configuration process or after the system performs validate configuration.
Select a value from the drop-down list in the Select Answer column, or enter a value in the Enter Answer column to change values for the segments.
Click the Validate Configuration button if dynamic configuration entry is disabled to verify that the error was corrected.
This section provides an overview of configured item inventory and discusses how to review configured item inventory.
The Advanced Configured Item Inventory Search program (P3220) locates inventory that can be used to fulfill the order for the configured item. When you initially enter the Configured Item Inventory Search form (W3220B), the default configuration is the configuration from the Configure Item form. Use an * (asterisk) in the Answer field to perform an open search for a segment. When you select a configured item from inventory, the system hard commits it to the sales order.
Access the Configured Item Inventory Search form.
Click to search the JD Edwards EnterpriseOne database for configured item inventory that matches the search criteria.
Click to access the View Configuration form (W32983B). Review the configuration tree, attributes, and segment answers for the configured item.
Click to add the selected record for the configured item in inventory to the order.
This section provides an overview of configured item history and discusses how to review configured item history.
If you select a configuration on the Configured Item History form, the system pushes the configuration values back to the configuration on the Configure Item form.
Access the Configured Item History form.
This section provides an overview of configured text and discusses how to review configured text.
Configured or generic text for a configured item is displayed in a media object. The generic text that is generated for a configured item is based on the setup that is defined on Configured Item Segments (P3291).
Part number of the configured parent.
Segment number.
Segment description.
Segment value.
Description of the associated UDC table value.
During order entry, the JD Edwards EnterpriseOne Configurator system generates one copy of text for each configured item and attaches it to the Configurator Master Table (F3201). The generic text can be accessed from a Row menu on an inquiry form in an order entry program such as Sales Order Entry (P4210), Purchase Order Entry (P4310), or Manufacturing Work Order Processing (P48013).
Attaching the generic text to the F3201 table, rather than directly to an order, enables both greater control of the text and use of the text for each order.
The Substitute Configured Item Text processing option on the Processing tab of the Configured Item Revisions program (P3210) controls how the generic text is generated. The processing option enables you either to replace all of the text every time a change is made or to append the new text to the bottom of the existing text.
If the system generates purchase orders for components of configured items during order entry, the configuration specific information is sent to the supplier in the form of media objects.
