9 Rerunning Preconversion Integrity Reports
This chapter contains the following topics:
9.1 Rerunning the Preconversion Integrity Reports
After you purge outdated data tables, you should rerun the integrity reports to ensure that the records that you purged were the ones that you intended to purge and that purging the records did not create any integrity issues.
If you do not rerun the integrity reports and correct any integrity issues, you have no proof that the tables were in balance before the base currency conversion. After the conversion, you do not have current integrity reports to compare to the post-integrity reports.
Rerun the integrity reports in proof mode and, if necessary, research and correct any data issues.
See Running Preconversion Integrity Reports.
Rerun the preconversion integrity reports and complete all remaining tasks in this guide in the test environment first, correcting any data issues in both the test and production environments. Later, when you are satisfied with the results of the conversion in the test environment, complete all of the tasks again in the production environment.
