Skip Headers
JD Edwards EnterpriseOne Applications Console Fundamentals Implementation Guide
Release 9.1
Part Number E15094-02
Home
Book List
Index
Contact Us
Next
PDF
Mobi
ePub
Contents
List of Figures
Title and Copyright Information
Preface
Audience
JD Edwards EnterpriseOne Products
Documentation Accessibility
Related Documents
Conventions and Screen Images
1
Introduction to JD Edwards EnterpriseOne Consoles
1.1
JD Edwards EnterpriseOne Console Overview
1.1.1
Metrics
1.1.2
Architecture
1.2
JD Edwards EnterpriseOne Console Business Process
1.3
JD Edwards EnterpriseOne Console Implementation
1.3.1
Global Implementation Steps
1.3.2
Console Implementation Steps
2
Setting Up Consoles
2.1
Understanding Console Security
2.2
Setting Up the Constants
2.2.1
Understanding User-Defined Codes
2.2.2
Understanding Next Numbers
2.2.3
Understanding Email and Distribution Lists
2.2.4
Understanding Charts
2.2.5
Understanding Analytics Currency
2.2.6
Forms Used to Set Up Constants
2.2.7
Defining Next Numbers
2.2.8
Setting Up Default Information
2.2.9
Setting Up Analytics Currency
2.3
Setting Up the Consoles
2.3.1
Understanding Console Setup
2.3.1.1
Metric Goals and Thresholds
2.3.1.2
Related Actions
2.3.1.3
Lists
2.3.2
Understanding Metrics on Multiple Consoles
2.3.3
Forms Used to Set Up Consoles
2.3.4
Setting Processing Options for the Dashboard Management Program (P80D301)
2.3.4.1
Display
2.3.5
2.3.6
Setting Up Metrics
2.3.7
Revising Configurations
2.3.8
Creating Metric Groups
2.3.9
Setting Up Search By Filters
2.3.10
Entering Metric Goals
2.3.11
Entering Related Action Definitions
2.3.12
Creating Lists
2.4
Loading Data
2.4.1
Understanding Data Loading
2.4.1.1
Currency
2.4.1.2
Reset Data Load Programs
2.4.2
Understanding Full and Incremental Data Loads
2.4.2.1
Example: Number of Days to Rebuild
2.4.3
Setting Processing Options for the Date Dimension Program (R80D100)
2.4.3.1
Processing
2.4.4
Running the Date Dimension Program (R80D100)
3
Setting Up Web Servers for Consoles
3.1
Understanding Web Server Setup
3.2
Setting Up Charts on the Web Server
3.2.1
Enabling Charts in Non-Windows Environments
3.3
Setting Up Font Listing JSP
3.3.1
Determining the Fonts on the Server
3.3.2
Reviewing the Fonts
3.4
Setting Up Asian Fonts on Servers
3.4.1
Setting Up WebSphere Running on Microsoft Windows Platforms
3.4.2
Setting Up OAS Running with Sun Microsystems JRE
3.4.3
Setting Up IBM iSeries
4
Using Consoles
4.1
Understanding the Dashboard Program
4.1.1
Console Summary Pages
4.1.2
Search By Fields
4.1.3
Console Detail Page
4.1.4
View By
4.1.5
Prerequisites
4.2
Understanding Console Portlets
4.3
Reviewing Metrics on the Console
4.3.1
Forms Used to Review Metrics on the Console
4.3.2
Setting Processing Options for the Dashboard Program (P80D350)
4.3.2.1
Display
4.3.3
Reviewing Summary Pages on the Console
4.3.4
Reviewing Detail Pages on the Console
5
Managing Alerts
5.1
Understanding Alerts
5.2
Setting Up the System for Alerts
5.2.1
Understanding System Setup
5.2.1.1
Distribution Lists
5.2.2
Forms Used to Set Up the System for Alerts
5.2.3
Setting Up Distribution Lists
5.2.4
Subscribing to Alerts
5.3
Defining Alerts
5.3.1
Understanding Alert Definitions
5.3.2
Form Used to Define Alerts
5.3.3
Defining Alerts
5.4
Reviewing and Responding to Alerts
5.4.1
Understanding the Alerts Instances Program (P80D357)
5.4.2
Prerequisites
5.4.3
Forms Used to Review and Respond to Alerts
5.4.4
Reviewing Alerts
5.4.5
A
Appendix: Tables Used by the JD Edwards EnterpriseOne Console
A.1
A.2
Prepopulated Tables
A.2.1
Financial Ratios Amount Dimensions Table
A.2.2
Goals Definition Cross Reference Table
A.2.3
Dashboard Code Metric Cross Reference Table
A.2.4
Metric Definition Table
A.2.5
Variant Definition Table
A.2.6
Hierarchy Definition Table
A.2.7
Action Definition Table
A.2.8
Metric Action Cross Reference Table
A.2.9
Alert Definition Table
A.2.10
Dashboard Configuration Table
A.2.11
UI Metric Group Definition Table
A.2.12
UI Metric Group Detail Table
B
Appendix: JD Edwards EnterpriseOne Console Data Movement Reports
B.1
JD Edwards EnterpriseOne Console Data Movement Reports: A to Z
Glossary
Index
Scripting on this page enhances content navigation, but does not change the content in any way.
