This appendix contains the following topics:
This appendix discusses the delivered workflow for JD Edwards EnterpriseOne Condition-Based Maintenance (CBM).
This section discusses the JD Edwards EnterpriseOne CBM workflow processes.
This section discusses the JD Edwards EnterpriseOne CBM notification process workflow.
The system sends a workflow notification message to a responsible person or persons within the maintenance team when the system receives a condition-based alert.
The system receives a CBM Alert that is flagged to create a notification message.
The responsible person or persons within the maintenance team receive a notification message indicating that a condition-based alert has been received by the system.
13
CBMNOTIFY
N1301040
CallCBMNotificationWorkflow
11, 11
This section discusses the JD Edwards EnterpriseOne CBM investigation process workflow.
The system can send a workflow investigation request message to a responsible person or persons within the maintenance team to investigate the condition-based alert that the system receives. When the investigation is complete, the system sends an investigation completed message to the original notification recipient.
The system receives a CBM Alert that is flagged with an automated response type of 2 to create an investigation request message. You can also manually trigger an investigation request message from the Condition-Based Alerts Workbench (P1310).
The responsible person or persons within the maintenance team receive an investigation message requesting they investigate the condition-based alert that was received in the system. The message provides a link to the Condition-Based Alerts Investigation Revisions form. On this form, the recipient can record investigation notes and indicate whether or not the investigation is complete. When the investigation is complete, the system sends another message to the original notification recipient.
13
CBMINVEST
N1301070
CallCBMInvestigationWorkflow
11
