A number that identifies an entry in the JD Edwards EnterpriseOne Address Book system, such as employee, applicant, participant, customer, supplier, tenant, or location. The address must be set up in the Address Book Master table (F0101).
An alphanumeric code that identifies a separate entity within a business for which you want to track costs. For example, a business unit might be a warehouse location, job, project, work center, branch, or plant.
You can assign a business unit to a document, entity, or person for purposes of responsibility reporting. For example, the system provides reports of open accounts payable and accounts receivable by business unit to track equipment by responsible department.
Use this code to refer to a branch or plant that might have departments or jobs, which represent lower-level business units, subordinate to it. For example:
Branch/Plant (MMCU)
Dept A (MCU)
Dept B (MCU)
Job 123 (MCU)
Business unit security might prevent you from viewing information about business units for which you have no authority.
A code that identifies a specific organization, fund, or other reporting entity. The company code must already exist in the Company Constants table (F0010) and must identify a reporting entity that has a complete balance sheet. At this level, you can have intercompany transactions.
Note: You can use company 00000 for default values such as dates and automatic accounting instructions. You cannot use company 00000 for transaction entries.
A central control or monitoring application for an enterprise software system. The console enables you to quickly analyze and assess performance on key performance indicators for your company.
Dashboard is synonymous with console in JD Edwards EnterpriseOne, however, console is the preferred term.
A number that identifies an entry in JD Edwards EnterpriseOne Foundation - Address Book, such as employee, applicant, participant, customer, supplier, tenant, or location.
You can use this number to locate and enter information about the address book record. If you enter a value other than the address book number (AN8), such as the long address or tax ID, you must precede it with the special character that is defined in JD Edwards EnterpriseOne Foundation - Address Book constants. When the system locates the record, it returns the address book number to the field.
For example, if address book number 4100 (Total Solutions) has a long address TOTAL and an * distinguishes it from other entries (as defined in JD Edwards EnterpriseOne Foundation - Address Book constants), you could type *TOTAL into the field, and the system would return 4100.
A number that the system assigns to an item. It can be in short, long, or third item number format.
Enter a value from UDC 41/P4 (Master Planning Family) that represents an individual Product Group or the name of a list of Product Group. Some examples include:
Laser Printer
Inkjet
Fax
Complete this field to create a user-defined code for a product family.
Enter a number that identifies an entry in JD Edwards EnterpriseOne Foundation - Address Book, such as employee, applicant, participant, customer, supplier, tenant, or location.
You can use this number to locate and enter information about the address book record. If you enter a value other than the address book number (AN8), such as the long address or tax ID, you must precede it with the special character that is defined in JD Edwards EnterpriseOne Foundation - Address Book constants. When the system locates the record, it returns the address book number to the field. For example, if address book number 4100 (Total Solutions) has a long address TOTAL and an * distinguishes it from other entries (as defined in JD Edwards EnterpriseOne Foundation - Address Book constants), you could type *TOTAL into the field, and the system would return 4100.
