This appendix contains the following topics:
This section discusses the JD Edwards EnterpriseOne Demand Scheduling workflow.
This section discusses the Demand Net Variance workflow.
The system sends a workflow message to a secured user whenever the Net Variance exceeds the notification level as defined by the user.
The Launch Demand Net Variance Workflow UBE initiates the Demand Net Variance Workflow process.
For each record in the Demand Detail Database table whose Net Variance exceeds the notification level, the system generates a workflow message.
40R
K40R110
R40R110
48
This section discusses the Inbound Wrapper Workflow Process.
This workflow executes several predefined business functions that the system calls either from a supplier default workflow or from a customer specific customized workflow. The system calls the predefined business functions to process inbound EDI demand based on the customer's business rules.
The Inbound Edit/Update UBE initiates a standard wrapper workflow, which initiates the workflow that you specify in the Demand Workflow Maintenance program.
The system passes the job number to the workflow to identify the cache that contains the inbound demand data to process; Sold To and Ship To are optional parameters that may be passed to the workflow. The system updates the Demand and CUM Tables according to the workflow request. It also validates production sequencing data in corresponding work center messages.
40R
K47171WF
R47171
Inbound Edit/Update
49
