This appendix contains the following topics:
This table lists the equipment cost analysis reports, sorted alphanumerically by report ID.
Report ID and Report Name | Description | Navigation |
R13801A
Export Equipment Cost |
Use this program to download the equipment costs that you calculated into a different software package for further analysis. | Equipment Cost Analysis (G13ECA), Export Equipment Cost |
Some reports include a more detailed description, as well as information about processing options.
If you want to download the equipment costs that you calculated into a different software package for further analysis, you use the Export Equipment Cost program (R13801A) to export the equipment cost detail information from the Equipment Analysis Costs table (F1383).
You can download the cost detail information by group or subgroups, and then display the information in the same way as in the Equipment Cost Analysis program (P13801) with the same types of totals. For example, Actual Total and Actual Total with Roll-up.
The text file that is generated by running the Export Equipment Cost program is saved to the export directory under the JD Edwards EnterpriseOne installation where the batch report is run. For example, if the report is generated locally, it is saved to C:\B9\PROD\export.
Processing options enable you to specify the default processing for programs and reports.
Specify the column-name default value for columns 01 through 10. The system uses these columns to control the way that the system displays cost information. You use the Equipment Cost Analysis Inquiry Columns program (P13804) to define the column names.
Specify how the system displays costs. If you leave this processing option blank, the system displays equipment costs. Values are:
Blank: Equipment
1: Account
Specify the date range which the system uses for displaying costs. Values are:
F: From/thru date
I: Inception to date
P: Period to date
Y: Year to date
