E Mapping Fields for Inbound Multisite Consolidations
This appendix contains the following topics:
E.1 Mapping Fields in the F1001Z1 Table
This section contains lists of the fields in the F1001Z1 table. The lists are group by required, optional, and ignored fields.
E.1.1 Required Fields in the F1001Z1 Table
The system has required fields in the F1001Z1 table. In some fields, blank is a value.
The system uses some of these fields to identify or control the transfer of consolidation information from the F1001Z1 table to the Multi-Site Consolidation Transfer File Header table (F1001). Values in the other fields are written to the F1001 table.
This table lists the required fields in the F1001Z1 table:
Field Name Alias Type Length Definition
EDI - User ID IAEDUS Alpha 10 Enter the user ID of the person who is running the process or the person who is to receive workflow messages about the transfer. This field, with IAEDBT and IAEDTN, uniquely identifies a specific transaction.
EDI - Batch Number IAEDBT Alpha 15 Enter a number that groups transactions for processing. This field, with IAEDUS and IAEDTN, uniquely identifies a specific transaction.
EDI - Transaction Number IAEDTN Alpha 22 Enter a number that identifies a transaction. This field, with the SZRC5 from the F1002Z1, uniquely identifies a specific line of a specific transaction. This field, with IAEDUS and IAEDBT, uniquely identifies a specific transaction.
Direction Indicator IADRIN Alpha 1 Enter a value that indicates that the record was written by an external system. The value in this field must be 1 for inbound transactions.
Transaction Action IATNAC Alpha 1 Enter A for transactions to be processed. No other values are valid.
EDI - Successfully Processed IAEDSP Alpha 1 Leave this field blank because the system populates it. The value N indicates that the transaction was not processed or was processed in error. After the transaction is successfully processed, the system changes the value in this field to Y.
Consolidation Name IACNAM Alpha 3 Enter the name of the consolidation. This value must exist in UDC table.
Period Number - General Ledger IAPN Number 2 Enter the general ledger period number of the transaction.
Fiscal Year IAFY Number 2 Enter the last two digits of the fiscal year.
Century IACTRY Number 2 The first two digits of the fiscal year.
Ledger Type IALT Alpha 2 Enter the ledger type of the transaction. This ledger type must exist in UDC 09/LT. If you leave this field blank, the system uses ledger type AA.
Document Company IACO Alpha 5 Enter the company of the transaction. This company must exist in the F0010 table.
E.1.2 Optional Fields in the F1001Z1 Table
The system has optional fields in the F1001Z1 table. They are not required to process multisite consolidations. The values in these fields are written to the F1001 table, but they are not used by the multisite consolidations programs.
This table lists the optional fields in the F1001Z1 table:
Category Code File Sent IACCSE Alpha 1 Enter a value indicates whether the Multi-Site Consolidation Transfer File - Category Codes table (F1003) was created for this consolidation. Values are:
Blank or 0: The table was not created
1: The table was created.
EDI - Line Number IAEDLN Number 7 Not used to process consolidations.
EDI - Document Type IAEDCT Alpha 2 Not used to process consolidations.
Type Transaction IATYTN Alpha 8 Not used to process consolidations.
EDI - Translation Format IAEDFT Alpha 10 Not used to process consolidations.
EDI - Transmission Date IAEDDT Date 6 Not used to process consolidations.
EDI - Detail Lines Processed IAEDDL Number 5 Not used to process consolidations.
Trading Partner ID IAPNID Alpha 15 Not used to process consolidations.
Transmission File Status IATRFG Alpha 1 Not used to process consolidations.
Number of Records Transmitted IATRSE Number 15 Not used to process consolidations.
Date - Sent IADTSE Date 6 Not used to process consolidations.
Number of Records Received IATRRC Number 15 Not used to process consolidations.
Date - Received IADTRI Date 6 Not used to process consolidations.
Prior Period Adjustments IAIN01 Alpha 1 Not used to process consolidations.
Debits = Credits IAIN02 Alpha 1 Not used to process consolidations.
Source UDC = Target UDC IAIN03 Alpha 1 Not used to process consolidations.
Source OBJ/Sub = Target OBJ/Sub IAIN04 Alpha 1 Not used to process consolidations.
Accounts Last Month Not This Month IAIN05 Alpha 1 Not used to process consolidations.
Business Units Last Month Not This Month IAIN06 Alpha 1 Not used to process consolidations.
Accounts This Month Not Last Month IAIN07 Alpha 1 Not used to process consolidations.
Business Units This Month Not Last Month IAIN08 Alpha 1 Not used to process consolidations.
Integrity Control Status 9 IAIN09 Alpha 1 Not used to process consolidations.
Integrity Control Status 10 IAIN10 Alpha 1 Not used to process consolidations.
Integrity Control Status 11 IAIN11 Alpha 1 Not used to process consolidations.
Integrity Control Status 12 IAIN12 Alpha 1 Not used to process consolidations.
E.1.3 Ignored Fields in the F1001Z1 Table
The system has fields in the F1001Z1 table that are not used. The system does not write the values in these fields to the 1001 table.
This table lists the ignored fields in the F1001Z1 table:
User Reserved Reference IAURRF Alpha 15
User Reserved Code IAURCD Alpha 2
User Reserved Code IAURC1 Alpha 3
User Reserved Code IAURC2 Alpha 10
User Reserved Amount IAURAT Number 15
User Reserved Number IAURAB Number 8
Transaction Originator IATORG Alpha 10
E.2 Mapping Fields in the F1002Z1 Table
E.2.1 Required Fields in the F1002Z1 Table
These fields are required in the F1002Z1 table. In some fields, blank is a value. The system uses some fields to identify or control the transfer of consolidation information from the F1002Z1 table to the F1002 table. Values in the other fields are written to the F1002 table.
This table lists the required fields in the F1002Z1 table:
EDI - User ID SZEDUS Alpha 10 Enter the user ID of the person who is running the process or the person who is to receive workflow messages about the transfer. This field, with SZEDBT and SZEDTN, uniquely identifies a specific transaction.
EDI - Batch Number SZEDBT Alpha 15 Enter a number used to group transactions for processing. This field, with SZEDUS and SZEDTN, uniquely identifies a specific transaction.
EDI - Transaction Number SZEDTN Alpha 22 Enter a number that identifies a transaction. This field, with SZRC5), uniquely identifies each transaction. This field, with SZEDUS and SZEDBT, also uniquely identifies a specific transaction.
File Line Identifier SZRC5 Number 5 Enter a number that, with SZEDTN, identifies each line of the transaction.
Direction Indicator SZDRIN Alpha 1 Enter 1 in for inbound transactions. this indicates that the record was written by an external system.
Transaction Action SZTNAC Alpha 1 Enter A for transactions to be processed. No other values are valid.
EDI - Successfully Processed SZEDSP Alpha 1 Leave this field blank because the system populates it. The number 0 indicates that the transaction was not processed or was processed in error. After the transaction is successfully processed, the system changes the value in the field to 1.
Business Unit SZMCU Alpha 12 Enter the business unit of the transaction. This value must be entered in the format that is defined in the account structure.
Object Account SZOBJ Alpha 6 Enter the object account of the transaction. This value must be entered in the format that is defined in the account structure.
Subsidiary SZSUB Alpha 8 Enter the subsidiary account of the transaction. This value must be entered in the format that is defined in the account structure.
Description SZDL01 Alpha 30 Enter a description of the account.
E.2.2 Optional Fields in the F1002Z1 Table
These fields are optional in the F1002Z1 table. They are not required to process multisite consolidations. The values in these fields are written to the F1002 table, but they are not used by the multisite consolidations programs.
This table lists the optional fields in the F1002Z1 table:
Subledger - G/L SZSBL Alpha 8 Enter a value that indicates the subledger for the transaction. If you complete this field, you must also enter a value in SZSBLT.
Subledger Type SZSBLT Alpha 1 Enter a value that indicates the subledger type for the transaction. If you enter a value in this field, the value must exist in UDC table 00/ST.
Currency Code - From SZCRCD Alpha 3 Enter a code that identifies the currency of the transaction. The value in this field must exist in the F0013 table.
Currency Code - Denominated In SZCRCX Alpha 3 Enter a code that identifies the currency in which the transaction was denominated. The value in this field must exist in the F0013 table.
Amount Beginning Balance/PYE Forward SZAPYC Number 15 Enter the cumulative prior year-end balance. The system uses this amount as the beginning balance for balance sheet and job cost accounts.
Amount - Net Posting 01 -
Amount - Net Posting 14
SZAN01 - SZAN14 Number 15 Enter the net amount that is posted during the specified accounting period. These fields represents accounting period 01–14. The system uses the accounting periods from the F0010 table. For each period, the net amount posted is the total of all debits and credits from the first day of the period through the last day of the period.
Amount - Prior Year Net Postings SZAPYN Number 15 Enter the prior year-end net postings. The system uses this number for profit and loss statement comparisons.
Amount - Week to Date SZAWTD Number 15 Not used to process consolidations.
Amount - Original/ Beginning Budget SZBORG Number 15 Not used to process consolidations.
Budget Requested SZBREQ Number 15 Not used to process consolidations.
Budget Approved SZBAPR Number 15 Not used to process consolidations.
E.2.3 Ignored Fields in the F1002Z1 Table
The fields in this table are ignored by the system. The system does not use or write values in these fields to the F1002 table.
This table lists the ignored fields in the F1002Z1 table:
User Reserved Reference SZURRF Alpha 15
User Reserved Code SZURCD Alpha 2
User Reserved Code SZURC1 Alpha 3
User Reserved Code SZURC2 Alpha 10
User Reserved Amount SZURAT Number 15
User Reserved Number SZURAB Number 8
Transaction Originator SZTORG Alpha 10
