| JD Edwards EnterpriseOne Applications Project and Government Contract Accounting Implementation Guide Release 9.1 Part Number E15113-01 |
PDF · Mobi · ePub |
This chapter contains the following topics:
Subcontract retention is a percentage of a committed amount that is held until a specified date after the order is complete. Retention processing applies to ongoing projects and only applies to services lines. Subcontract retention is not applicable to inventory based purchase order lines where the full cost of the product is due upon receipt of the product.
In some industries, subcontract retention may be called retainage. Thus, the terms retainage and retention may be used interchangeably.U.S. federal government requirements prohibit the billing of unpaid expenses. In the JD Edwards EnterpriseOne system, you use retainage functionality to automate the recording of retention to nonbillable accounts for transactions with an inventory interface of A and B only. The system uses financial automatic accounting instruction (AAI) PCNBRT for retainage processing during voucher match. To enable the subcontract retention functionality in the JD Edwards EnterpriseOne system, you must:
Select the Non-Billable Retainage option on the Line Type Constants Revisions form (W40205B).
New journal ledger entries are created if this subcontract retention option is selected.
Perform two-way voucher match.
Ensure that the retainage amount is not zero.
Before entering an order that includes retention, select the Display Retainage Indicator processing option on the Display tab of the Subcontract Order Entry program (P4310). When you enter an order that has retainage, select the Retainage Indicator check box on the order header form. This field notifies the AP clerk during the voucher match process to double-check the invoice from the supplier to see if there was an amount retained on the invoice. The Retainage Indicator check box can be used with or without the Retainage Percentage field.
You can display the Retainage Indicator field in the detail grid on the Voucher Match form by setting the Display Retainage Indicator processing option on the Display tab of the Voucher Match program (P4314). The system retrieves the retainage indicator setting from the order header. You also set the processing options on the Retainage tab of the P4314 program.
When performing voucher match, you can relieve commitments to billable and nonbillable accounts. The setting of the Non-Billable Retainage option on the Line Type Constants Revisions form determines whether the system uses the new nonbillable automatic accounting instruction (AAI) for retainage. Select this option to specify that the system use the financial AAI nonbillable retainage (PCNBRT) for retainage processing during voucher match.
See Also:
