Specify the appellation code to appear on the report. If you enter both the appellation and growing area codes, the system prints only those harvest records that match both codes.
Enter a unique identifier representing a farming activity. Values are set up in the Farming Activities Additional Configuration program (P40G75), which is accessed from the Configured Operation Setup program (P31B75P).
Designates this operations as a farming operation. Farming operations are used in grower applications. The Grower option must also be selected in the Base Operation definition to activate the Farming operation.
Specify the geographic ID that the system uses to filter the displayed harvests on the Harvest Workbench. Use the search button to select from the list of valid geographic IDs, or leave the processing option blank to filter on all geographic IDs.
Enter the grower cost center that the system uses as default. This field appears only when system SY40G has been activated.
Designates this operation as a grower operation if this option is selected. Examples of grower operation include farming and spraying. Operations, such as QA and weigh tag can also be used in grower applications if this option is selected.
Enter a UDC (40G/HP) that represents the harvest pattern. The harvest pattern is used as a default and can be overridden on the block before it is saved.
Specify the harvest status code that the system uses to filter the harvests that are displayed on the Harvest Workbench. use the search button to select from the list of valid harvest status codes, or leave the processing option to blank to filter on all harvest status codes.
