36 Understanding Blocks, Registers and Records for FCont Requirements
This chapter contains the following topics:
36.1 Block 0 Registers for FCont
You generate block 0 registers and records to provide opening, identification, and reference information for the electronic files that you submit for FCont reporting.
The system writes records for block 0 registers when you run the Block 0 Generation program (R76B840) from the FCONT SPED Job Administrator program (P76B940).
36.1.1 Source and Output Tables
The system reads these tables to obtain the data for block 0 registers:
  • Address Book Master (F0101)
  • Address Book - Who's Who (F0111)
  • Address by Date (F0116)
  • Address Book Inscription - BR (F76B140)
  • Legal Company Constants - BR (F76B010)
The system writes the data for block 0 registers in the following table:
  • SPED Process (F76B940)
  • SPED Process Detail (F76B943)
36.1.2 Contents of Block 0 Registers
This table describes the contents of the registers for block 0:
Registers Description of Contents Compliance and Occurrence
0000
Flat File Opening and Company Identification
Includes information about the date of the file and company information from the company address book record and related tables. One only register 0000 must be present in the electronic file.
36.1.3 SPED FCont - Block 0 – Generation (R76B840)
The system generates the supported registers for block 0 when you run the SPED FCont - Generation program (R76B840). This program identifies the master information that will be used in block 0 and updates the F76B943 table with the UBE name, register type, line sequence and the text of the register type.
The system also generates a report that you use to verify the data generated. The report includes the most relevant information, whether registers were successfully generated, and the errors in the registers, if any. If an error exists, the system does not include any of the related records for the register. For example, if a register includes details about the records in another register, the system does not populate the fields for either register if an error exists for one or the other register. You can correct errors and rerun the report as many times as necessary to complete the file generation with no errors.
To be able to see errors in registers, you must set up the UBE to show details. See Extracting and Reviewing Data for FCont
36.2 Block I Registers for FCont
You generate block I registers and records to provide general information, account balances and accounting journal information for the electronic files that you submit for FCont reporting. Multiple programs exist to populate the records for block I.
The system writes records for block I registers when you run the following programs:
  • Block I - General Information program (R76B841)
  • Block I - Account Balances program (R76B842)
  • Block I - Accounting Journal program (R76B843)
You use the FCONT SPED Job Administrator program (P76B940) to run these batch programs.
36.2.1 Source and Output Tables
The system reads these tables to obtain the data for block I registers:
  • Business Unit Master (F0006)
  • Account Master (F0901)
  • Account Balances (F0902)
  • Account Ledger (F0911)
  • FCONT Account Ledger Operations (F76B835)
  • Legal Company Subsidiaries (F76B015)
  • Additional Account Information (F76B925)
The system writes the data for block I registers in the following table:
  • Job Accounts (F76B955)
36.2.2 Contents of Block I Registers
This table describes the contents of the registers for block I:
I001
Block I Opening
Includes a hard-coded value to indicate that records exist in the file. This register must be present in the electronic file.
One record exists in this register.
I050
Chart of Accounts
Includes account information including dates, level of the account, and referential account.
As the system processes accounts for this register, it saves the account data to the SPED Job Accounts - BR table so that the information can be used to validate data required for fields in this register and in other blocks registers.
Multiple records can exist in this register.
I051
Referential Chart of Accounts
Includes referential account information that you set up in the Referential Chart of Accounts program (P76B920). Multiple records can exist in this register.
The system populates this register for analytical accounts only. Analytical accounts are those that have a value of A in field 4 of the I050 register.
I075
Standard Historic Table
The system shows this register with no values. The system shows this register with no values.
I100
Costs Center
Includes information about the cost centers for the accounts informed on Register I051. This register is mandatory.
I150
Periodic Balances – Period Identification
Includes the first and last calendar date for the quarter/year. This register is mandatory. This register contains a single record.
I155
Periodic Balances Details
Includes the initial balance, sum of the positive transactions, sum of the negative transactions, and the final account balance. Multiple records can exist in this register.
The system includes records for each analytical account with a balance or that had transactions.
I200
Accounting Journal
Includes information about all F0911 batches considered as journal entries for FCont generated for a date range defined in the job and the FCont journal entries operations (from UDC 76B/FA). Multiple records can exist in this register.
I250
Journal Entry Lines
Includes the details of posted journal entries identified in the I200 register for the ledger types identified in the Book Type Definition program (P76B935). Multiple records can exist in this register.
I350
P/L Accounts Balances Before Closing – Date Identification
Includes the last day of the processed quarter/year. This register is mandatory. This register contains a single record.
I355
P/L Accounts Details Balances Before Closing
Includes the accumulated Final Account Balance by PL account for the quarter/year indicated in register I350. These amounts are retrieved from F0902 table. This register is mandatory. This register can include multiple records.
I990
Block I Closing
Includes the total number of lines in the block. This register must be present in the electronic file.
This register is generated by the Block 9 - Generation program (R76B846).
36.2.3 SPED FCont - Block I – General Information (R76B841)
The system generates the supported registers for block I when you run the SPED FCont - Block I - General Information program (R76B841). This program identifies the information about the chart of accounts and cost centers that you set up in the Account Master (F0901) and Brazilian Account Information (F76B925) tables. This program populates the registers for I001, I050, I051, I075 and I100.
All accounts processed by this UBE must have account group code configured through P76B925 application. Otherwise, the accounts will not be informed on text files.
36.2.4 SPED FCont - Block I – Account Balances (R76B842)
The system generates the supported registers for block I when you run the SPED FCont - Block I - Account Balances program (R76B842). This program generates information about the beginning and ending PL balances. It populates the records for registers I150, I155, I350, and I355.
Set the processing option for this program before running it from the SPED Job Administrator program. The processing option determines which registers to populate.
36.2.4.1 Setting Processing Options for Block I - Account Balances (R76B842)
Processing options enable you to specify default processing values.
1. Registers to generate
Specify the register to generate. Values are:
Blank: Periodic Balances (Registers I150/I155). The system filters records by ledger type and generates accumulated positive and negative amounts for the accounts processed.
1: PL accounts Balances (Registers I350/I355). The system generates records for the PL account balances.
36.2.5 SPED FCont - Block I – Accounting Journal (R76B843)
The system generates the supported registers for block I when you run the SPED FCont - Block I - Accounting Journal program (R76B843). This program generates information about journal entry batches and the journal entry lines of each batch. It populates the records for registers I200 and I250.
36.3 Block J Registers for FCont
You generate block J registers and records to provide signatories information for the electronic files that you submit for FCont reporting.
The system writes records for block J registers when you run the Block J Signatories program (R76B844) from the FCONT SPED Job Administrator program (P76B940).
36.3.1 Source and Output Tables
The system reads these tables to obtain the data for block J registers:
  • Brazilian Address Book (F76011)
  • Address Number Inscriptions (F76B140)
The system writes the data for block J registers in the following table:
  • SPED Job Signatories (F76B945)
36.3.2 Contents of Block J Registers
This table describes the contents of the registers for block J:
J001
Block J Opening
J930
Bookkeeping Signatories identification
Includes the signatory information for the SPED FCont electronic file. Multiple registers can exist in the electronic file.
J990
Block J Closing
This register is generated by the Block 9 Generation program (R76B846).
36.3.3 SPED FCont - Block J – Signatories (R76B844)
The system generates the supported registers for block J when you run the SPED FCont - Block J - Signatories program (R76B844). This program generates information about the signatories for the SPED FCont file and generates the register J930.
36.4 Block M Registers for FCont
You generate block M registers and records to provide fiscal register information for the electronic files that you submit for FCont reporting.
The system writes records for block M registers when you run the Block M Fiscal Register program (R76B845) from the FCONT SPED Job Administrator program (P76B940).
36.4.1 Source and Output Tables
The system reads these tables to obtain the data for block M registers:
  • FCONT Account Balances (F76B837)
The system writes the data for block M registers in the following table:
  • FCONT Job Account Balances (F76B845)
36.4.2 Contents of Block M Registers
This table describes the contents of the registers for block M:
M001
Block M Opening
M020
Juridic person qualification
Indicates the qualification of Juridic Person (UDC 76B/JQ), to identify who manages the reference chart of accounts (used for registration I051). This register must be present in the electronic file.
M025
Initial balances for recovered equity accounts
Indicates the fiscal and corporate balances of recovered equity account (Assets, Liabilities and Equity) from immediately preceding period bookkeeping. This register must be present in the electronic file.
M030
Assessment quarter identification
Includes the calculation periods contained in FCont. This register must be present in the electronic file.
M155
FCont quarter balances detail
Includes the detail of the FCONT periodic balances from balance sheet accounts. This register is mandatory.
M355
Income accounts detail balances before closing
Indicates the balance references (corporate and fiscal) of income accounts before closure. This register is mandatory.
M990
Block M Closing
36.4.3 SPED FCont - Block M – Fiscal Register (R76B845)
The system generates the supported registers for block M when you run the SPED FCont - Block M - Fiscal Register program (R76B845). This program generates information about the FCONT quarter balances detail and recovered adjustments for the SPED FCont file and generates the registers M001, M020, M025, M030, M155, and M355.
36.5 Block 9 Registers for FCont
You generate block 9 registers and records to provide closing information for the electronic files that you submit for FCont reporting. In addition to the registers in block 9, the Block 9 Generation programs writes the data to the closing registers for blocks I, J, and M.
36.5.1 Source and Output Tables
The system reads these tables to obtain the data for block 9 registers:
  • FCONT Jobs Accounts Balances (F76B845)
The system writes the data for block 9 registers in the following tables:
  • Text Processor Header (F007101)
  • Text Processor Detail (F007111)
  • SPED Job Output Detail (F76B943)
  • SPED Job Batches (F76B944)
36.5.2 Contents of Block 9 Registers
This table describes the contents of the registers for block 9:
9001
Block 9 Opening
Includes a hard-coded value to indicate that records exist in the file. This register is mandatory.
One register exists in the electronic file.
9900
Block 9 File Registers
Includes information about the total number of records for each type in the flat file. This register is mandatory.
Multiple registers can exist in the file.
9990
Block 9 Closing
Includes the total number of lines for block 9. This register is mandatory.
9999
Flat File Closing
Includes the total number of lines for the electronic file. This register is mandatory.
36.5.3 SPED FCont - Block 9 – Generation (R76B846)
The system generates the supported registers for block 9 when you run the SPED FCont - Block 9 - Generation program (R76B844). This program identifies the master information that will be used in block 9 and updates the F76B943 table with the UBE name, register type, line sequence and the text of the register type.
