8 Printing Fixed Asset Reports for Hungary
This chapter contains the following topics:
8.1 Understanding Fixed Asset Reports for Hungary
The Asset Movement Schedule Report program (R741202) enables you to periodically review all of the changes to asset category costs due to additions, adjustments, revaluations, retirements, and reclassifications. This report also shows the account and totals for property type and company.
The Accumulated Depreciation Asset Movement Report program (R741201) enables you to periodically review all of the changes to asset-category accumulated depreciation values due to additions, adjustments, revaluations, retirements, and reclassifications. This report also shows the account and totals for property type and company.
8.2 Running the Accumulated Depreciation Asset Movement Report Program
Select Fixed Asset Processing (G74H12), Accumulated Depreciation Asset Movement Report.
8.3 Setting Processing Options for Accumulated Depreciation Asset Movement Report (R741201)
Processing options enable you to specify default processing values.
8.3.1 Process
Company
Enter the company for which you run the report.
Ledger Type
Enter a value that exists in the Ledger Type (09/LT) user-defined code (UDC) table to specify the ledger in which the records to report exist.
Setup Code
Enter a value that exists in the Setup Code (74/ST) UDC table to specify the grouping of columns and document types on which to report. You must complete this processing option.
Period Number From
Enter the first period in a range of periods for which to generate the report.
Fiscal Year From
Enter the beginning year in a range of years for which to generate the report.
Period Number Thru
Enter the ending period in a range of periods for which to generate the report.
Fiscal Year Thru
Enter the ending year in a range of years for which to generate the report.
Product Code
Enter a value that exists in the System Code (98/SY) to specify the system in which the fixed asset records exist.
User Defined Code
Enter the UDC code that is associated with the value that you entered in the Product Code processing option to define the tangible or intangible assets.
8.4 Running the Asset Movement Schedule Report Program
Select Fixed Asset Processing (G74H12), Asset Movement Schedule Report.
8.5 Setting Processing Options for Asset Movement Schedule Report (R741202)
8.5.1 Process
Company
Enter the company for which to run the report.
Ledger Type
Enter a value that exists in the Ledger Type (09/LT) UDC table to specify the ledger in which the records to report exist.
Setup Code
Period Number From
Fiscal Year From
Period Number Thru
Fiscal Year Thru
Product Code
User Defined Code
