Welcome to Release 9.1.2 of the Oracle JD Edwards EnterpriseOne Environmental Accounting and Reporting User's Guide.
This guide contains the information needed to implement and use JD Edwards EnterpriseOne Environmental Accounting and Reporting.
See Related Information Sources for more Oracle Applications product information.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Oracle customers have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
This appendix lists each form available for use in the JD Edwards EnterpriseOne Environmental Accounting and Reporting application, as well as the associated navigator path for each form.
JD Edwards EnterpriseOne Tools System Administration Guide
JD Edwards EnterpriseOne Address Book Implementation Guide
JD Edwards EnterpriseOne General Accounting Implementation Guide
JD Edwards EnterpriseOne Financial Management Application Fundamentals Implementation Guide
JD Edwards EnterpriseOne Inventory Management Implementation Guide
JD Edwards EnterpriseOne Accounts Payable Implementation Guide
JD Edwards EnterpriseOne Capital Asset Management Implementation Guide
Customers must conform to the supported platforms for the release as detailed in the JD Edwards EnterpriseOne minimum technical requirements. In addition, JD Edwards EnterpriseOne may integrate, interface, or work in conjunction with other Oracle products. Refer to the cross-reference material in the Program Documentation at http://oracle.com/contracts/index.html for Program prerequisites and version cross-reference documents to assure compatibility of various Oracle products.
Oracle STRONGLY RECOMMENDS that you never use SQL*Plus, Oracle Data Browser, database triggers, or any other tool to modify Oracle E-Business Suite data unless otherwise instructed.
Oracle provides powerful tools you can use to create, store, change, retrieve, and maintain information in an Oracle database. But if you use Oracle tools such as SQL*Plus to modify Oracle E-Business Suite data, you risk destroying the integrity of your data and you lose the ability to audit changes to your data.
Because Oracle E-Business Suite tables are interrelated, any change you make using an Oracle E-Business Suite form can update many tables at once. But when you modify Oracle E-Business Suite data using anything other than Oracle E-Business Suite, you may change a row in one table without making corresponding changes in related tables. If your tables get out of synchronization with each other, you risk retrieving erroneous information and you risk unpredictable results throughout Oracle E-Business Suite.
When you use Oracle E-Business Suite to modify your data, Oracle E-Business Suite automatically checks that your changes are valid. Oracle E-Business Suite also keeps track of who changes information. If you enter information into database tables using database tools, you may store invalid information. You also lose the ability to track who has changed your information because SQL*Plus and other database tools do not keep a record of changes.
