Note: This page uses Javascript. You are seeing this note because your browser either doesn't support Javascript or Javascript is turned off. To view this help system as it is meant to be viewed please use a Javascript enabled browser.
Previous Topic
Next Topic
SDEF Conversion
Use the SDEF Conversion utility to convert your projects to/from SDEF (Standard Data Exchange Format). The SDEF format enables users of different project management tools to exchange project data.
Click here for the SDEF Conversion Guide
Copyright information
