Database statistics
The DB->stat() method returns a set of statistics about the underlying database, for example, the number of key/data pairs in the database, how the database was originally configured, and so on.
There is a flag you can set to avoid time-consuming operations:
DB_FAST_STAT
Return only information that can be acquired without traversing the entire database.
