Dbstl memory management
Freeing memory
Type specific notes
Freeing memory
When using dbstl, make sure memory allocated in the heap is released after use. The rules for this are:
  • dbstl will free/delete any memory allocated by dbstl itself.
  • You are responsible for freeing/deleting any memory allocated by your code outside of dbstl.
Type specific notes
When you open a DbEnv or Db object using dbstl::open_env() or dbstl::open_db(), you do not need to delete that object. However, if you new'd that object and then opened it without using the dbstl::open_env() or dbstl::open_db() methods, you are responsible for deleting the object.
Note that you must new the Db or DbEnv object, which allocates it on the heap. You can not allocate it on the stack. If you do, the order of destruction is uncontrollable, which makes dbstl unable to work properly.
You can call dbstl_exit() before the process exits, to release any memory allocated by dbstl that has to live during the entire process lifetime. Releasing the memory explicitly will not make much difference, because the process is about to exit and so all memory allocated on the heap is going to be returned to the operating system anyway. The only real difference is that your memory leak checker will not report false memory leaks.
dbstl_exit() releases any memory allocated by dbstl on the heap. It also performs other required shutdown operations, such as closing any databases and environments registered to dbstl and shared across the process.
If you are calling the dbstl_exit() function, and your DbEnv or Db objects are new'd by your code, the dbstl_exit() function should be called before deleting the DbEnv or Db objects, because they need to be closed before being deleted. Alternatively, you can call the dbstl::close_env() or dbstl::close_db() functions before deleting the DbEnv or Db objects in order to explicitly close the databases or environments. If you do this, can then delete these objects, and then call dbstl_exit().
Only when you are storing raw bytes (such as a bitmap) do you have to store and retrieve data by using the DbstlDbt helper class. Although you also can do so simply by using the Berkeley DB Dbt class, the DbstlDbt class offers more convenient memory management behavior.
When you are storing DbstlDbt objects (such as db_vector<DbstlDbt>), you must allocate heap memory explicitly using the malloc() function for the DbstlDbt object to reference, but you do not need to free the memory – it is automatically freed by the DbstlDbt object that owns it by calling the standard C library free() function.
However, because dbstl supports storing any type of object or primitive data, it is rare that you would have to store data using DbstlDbt objects while using dbstl. Examples of storing DbstlDbt objects can be found in the TestAssoc::test_arbitrary_object_storage() and TestAssoc::test_char_star_string_storage() functions, which are available in the dbstl test suite.
