Release 3.1: DB_ENV->set_tx_recover
The redo parameter of the function passed to DB_ENV->set_tx_recover used to be an integer set to any one of a number of #defined values. In the 3.1 release of Berkeley DB, the redo parameter has been replaced by the op parameter which is an enumerated type of type db_recops.
If your application calls DB_ENV->set_tx_recover, then find the function referred to by the call. Replace the flag values in that function as follows:
Previous flag Berkeley DB 3.1 version flag
TXN_BACKWARD_ROLL DB_TXN_BACKWARD_ROLL
TXN_FORWARD_ROLL DB_TXN_FORWARD_ROLL
TXN_OPENFILES DB_TXN_OPENFILES
TXN_REDO DB_TXN_FORWARD_ROLL
TXN_UNDO DB_TXN_ABORT
