Release 4.2: DB_CLIENT
The flag to create a client to connect to a RPC server was renamed from DB_CLIENT to DB_RPCCLIENT, in order to avoid confusion between RPC clients and replication clients. Applications using the DB_CLIENT flag should change that use to DB_RPCCLIENT; no other change is required.
