Chapter 40. Upgrading Berkeley DB 4.2 applications to Berkeley DB 4.3
Table of Contents
Release 4.3: Introduction
Release 4.3: Java
Release 4.3: DB_ENV->set_errcall, DB->set_errcall
Release 4.3: DBcursor->c_put
Release 4.3: DB->stat
Release 4.3: DB_ENV->set_verbose
Release 4.3: Logging
Release 4.3: DB_FILEOPEN
Release 4.3: ENOMEM and DbMemoryException
Release 4.3: Replication
Release 4.3: Run-time configuration
Release 4.3: Upgrade Requirements
Berkeley DB 4.3.29 Change Log
Database or Log File On-Disk Format Changes:
New Features:
Database Environment Changes:
Concurrent Data Store Changes:
General Access Method Changes:
Btree Access Method Changes:
Hash Access Method Changes:
Queue Access Method Changes:
Recno Access Method Changes
C++-specific API Changes:
Java-specific API Changes:
Tcl-specific API Changes:
RPC-specific Client/Server Changes:
Replication Changes:
XA Resource Manager Changes:
Locking Subsystem Changes:
Logging Subsystem Changes:
Memory Pool Subsystem Changes:
Transaction Subsystem Changes:
Utility Changes:
Configuration, Documentation, Portability and Build Changes:
The following pages describe how to upgrade applications coded against the Berkeley DB 4.2 release interfaces to the Berkeley DB 4.3 release interfaces. This information does not describe how to upgrade Berkeley DB 1.85 release applications.
