Retrieving records
The DB->get() method retrieves records from the database. In general, DB->get() takes a key and returns the associated data from the database.
There are a few flags that you can set to customize retrieval:
Search for a matching key and data item, that is, only return success if both the key and the data items match those stored in the database.
Read-modify-write: acquire write locks instead of read locks during retrieval. This can enhance performance in threaded applications by reducing the chance of deadlock.
If the underlying database is a Btree, and was configured so that it is possible to search it by logical record number, retrieve a specific record.
If the database has been configured to support duplicate records, DB->get() will always return the first data item in the duplicate set.
