Chapter 27.  Building Berkeley DB for UNIX/POSIX
Table of Contents
Building for UNIX/POSIX
Configuring Berkeley DB
Building a small memory footprint library
Changing compile or load options
Installing Berkeley DB
Dynamic shared libraries
Running the test suite under UNIX
Architecture independent FAQ
Mac OS X
The Berkeley DB distribution builds up to four separate libraries: the base C API Berkeley DB library and the optional C++, Java, and Tcl API libraries. For portability reasons, each library is standalone and contains the full Berkeley DB support necessary to build applications; that is, the C++ API Berkeley DB library does not require any other Berkeley DB libraries to build and run C++ applications.
Building for Linux, Mac OS X and the QNX Neutrino release is the same as building for a conventional UNIX platform.
The Berkeley DB distribution uses the Free Software Foundation's autoconf and libtool tools to build on UNIX platforms. In general, the standard configuration and installation options for these tools apply to the Berkeley DB distribution.
To do a standard UNIX build of Berkeley DB, change to the build_unix directory and then enter the following two commands:
This will build the Berkeley DB library.
To install the Berkeley DB library, enter the following command:
make install
To rebuild Berkeley DB, enter:
make clean
If you change your mind about how Berkeley DB is to be configured, you must start from scratch by entering the following command:
make realclean
To uninstall Berkeley DB, enter:
make uninstall
To build multiple UNIX versions of Berkeley DB in the same source tree, create a new directory at the same level as the build_unix directory, and then configure and build in that directory as described previously.
