Skip Headers
Oracle® Database PL/SQL Language Reference
11g Release 2 (11.2)
Part Number E17126-03
Go to Documentation Home
Home
Go to Book List
Book List
Go to Table of Contents
Contents
Go to Index
Index
Go to Master Index
Master Index
Go to Feedback page
Contact Us
Go to previous page
Previous
Go to next page
Next
View PDF
DROP TYPE BODY Statement
The DROP TYPE BODY statement drops the body of an ADT, VARRAY type, or nested table type. When you drop a type body, the type specification still exists, and you can re-create the type body. Prior to re-creating the body, you can still use the type, although you cannot invoke its member functions.
Topics:
Prerequisites
The type body must be in your own schema or you must have the DROP ANY TYPE system privilege.
Syntax
drop_type_body ::=
drop_type_body
Semantics
schema
The name of the schema containing the type. The default is your own schema.
type_name
The name of the type body to be dropped.
Restriction on type_name You can drop a type body only if it has no type or table dependencies.
Example
Dropping an ADT Body: Example This statement removes the ADT body data_typ1. See "ADT Examples" for the example that creates this ADT.
DROP TYPE BODY data_typ1;
Related Topics
