Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Data Services Developer's Guide     Oracle Solaris Cluster
search filter icon
search icon
Document Information
Preface
1.  Overview of Resource Management
2.  Developing a Data Service
Analyzing the Application for Suitability
Determining the Interface to Use
Setting Up the Development Environment for Writing a Data Service
How to Set Up the Development Environment
Transferring a Data Service to a Cluster
Setting Standard Properties
Cluster Properties
Resource Type Properties
Resource Properties
Resource Group Properties
Resource Property Attributes
Node List Properties
Setting Resource and Resource Type Properties
Declaring Resource Type Properties
Declaring Resource Type Properties for a Zone Cluster
Declaring Resource Properties
Declaring Extension Properties
Implementing Callback Methods
Accessing Resource and Resource Group Property Information
Idempotence of Methods
How Methods Are Invoked in Zones
Generic Data Service
Controlling an Application
Starting and Stopping a Resource
Using Start and Stop Methods
Deciding Which Start and Stop Methods to Use
Using the Optional Init, Fini, and Boot Methods
Using the Init Method
Using the Fini Method
Guidelines for Implementing a Fini Method
Using the Boot Method
Monitoring a Resource
Implementing Monitors and Methods That Execute Exclusively in the Global Zone
Adding Message Logging to a Resource
Providing Process Management
Providing Administrative Support for a Resource
Implementing a Failover Resource
Implementing a Scalable Resource
Validation Checks for Scalable Services
Writing and Testing Data Services
Using TCP Keep-Alives to Protect the Server
Testing HA Data Services
Coordinating Dependencies Between Resources
Legal RGM Names
RGM Legal Names
Rules for Names Except Resource Type Names
Format of Resource Type Names
RGM Values
3.  Resource Management API Reference
4.  Modifying a Resource Type
5.  Sample Data Service
6.  Data Service Development Library
7.  Designing Resource Types
8.  Sample DSDL Resource Type Implementation
9.  Solaris Cluster Agent Builder
10.  Generic Data Service
11.  DSDL API Functions
12.  Cluster Reconfiguration Notification Protocol
A.  Sample Data Service Code Listings
B.  DSDL Sample Resource Type Code Listings
C.  Requirements for Non-Cluster Aware Applications
D.  Document Type Definitions for the CRNP
E.  CrnpClient.java Application
Index
Chapter 2
This chapter tells you how to make an application highly available or scalable, and provides detailed information about developing a data service.
This chapter covers the following topics:
