Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster Data Services Planning and Administration Guide Oracle Solaris Cluster |
1. Planning for Oracle Solaris Cluster Data Services
2. Administering Data Service Resources
Oracle Solaris Cluster Data Services Planning and Administration Guide explains how to install and configure Oracle Solaris Cluster data services.
Note - This Oracle Solaris Cluster release supports systems that use the SPARC and x86 families of processor architectures: UltraSPARC, SPARC64, AMD64, and Intel 64. In this document, x86 refers to the larger family of 64-bit x86 compatible products. Information in this document pertains to all platforms unless otherwise specified.
This document is intended for system administrators with extensive knowledge of Oracle software and hardware. Do not use this document as a planning or presales guide. Before reading this document, you should have already determined your system requirements and purchased the appropriate equipment and software.
The instructions in this book assume knowledge of the Oracle Solaris Operating System and expertise with the volume-manager software that is used with Oracle Solaris Cluster software.
This document contains information about commands that are specific to installing and configuring Oracle Solaris Cluster data services. The document does not contain comprehensive information about basic UNIX commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Online documentation for the Oracle Solaris Operating System
Oracle Solaris Operating System man pages
Other software documentation that you received with your system
The following table describes the typographic conventions that are used in this book.
Table P-1 Typographic Conventions
The following table shows the default UNIX system prompt and superuser prompt for shells that are included in the Oracle Solaris OS. Note that the default system prompt that is displayed in command examples varies, depending on the Oracle Solaris release.
Table P-2 Shell Prompts
Information about related Oracle Solaris Cluster topics is available in the documentation that is listed in the following table. All Oracle Solaris Cluster documentation is available at http://www.oracle.com/technetwork/indexes/documentation/index.html.
For a complete list of Oracle Solaris Cluster documentation, see the release notes for your release of Oracle Solaris Cluster at http://www.oracle.com/technetwork/indexes/documentation/index.html.
Third-party URLs that are referenced in this document provide additional related information.
Note - Oracle is not responsible for the availability of third-party web sites mentioned in this document. Oracle does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Oracle will not be responsible or liable for any actual or alleged damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
See the following web sites for additional resources:
Oracle Technology Network offers a range of resources related to Oracle software:
Discuss technical problems and solutions on the Discussion Forums.
Get hands-on step-by-step tutorials with Oracle By Example.
If you have problems installing or using Oracle Solaris Cluster, contact your service provider and provide the following information:
Your name and email address (if available)
Your company name, address, and phone number
The model number and serial number of your systems
The release number of the Oracle Solaris Operating System (for example, Oracle Solaris 10)
The release number of Oracle Solaris Cluster (for example, Oracle Solaris Cluster 3.3)
Use the following commands to gather information about each node on your system for your service provider.
Also have available the contents of the /var/adm/messages file.
