Skip Navigation Links
Exit Print View
Oracle Solaris Cluster 3.3 5/11 Release Notes     Oracle Solaris Cluster
search filter icon
search icon
Document Information
Preface
What's New in the Oracle Solaris Cluster 3.3 5/11 Software
Enhancements to the cluster check Command as a Cluster Validation Tool
Fencing Support for Sun ZFS Storage Appliance as a NAS Device
Support for Oracle ACFS as a Cluster File System
Zone Cluster Support for Loopback Mounts With HAStoragePlus Using ZFS
Configuration Wizard Support for Oracle 11g Release 2 with HA-Oracle and Oracle RAC
Support for Zone Clusters Without IP Addresses
Support for SWIFTAlliance Access 7.0 and SWIFTAlliance Gateway 7.0
Restrictions
Veritas Volume Manager Cluster Feature No Longer Supported
Commands Modified in This Release
Product Name Changes
Compatibility Issues
Node Panic When Calling rename(2) to Rename an Oracle ACFS Directory to its Parent Directory (11828617)
Node Fails To Start Oracle Clusterware After a Panic (uadmin 5 1) Fault Injection (11828322)
Need Support for Clusterized fcntl by Oracle ACFS (11814449)
Unable to Start Oracle ACFS in Presence of Oracle ASM in a Non-Global Zone (11707611)
Oracle Solaris Cluster Project Shares Workflow Should Return All Shares Underneath r/w Projects (7041969)
SAP startsap Fails to Start the Application Instance if startsrv Is Not Running (7028069)
Problem Using Sun ZFS Storage Appliance as Quorum Device Through Fibre Channel or iSCSI (6966970)
Cluster Zone Won't Boot Up After Live Upgrade on ZFS Root (6955669)
Solaris Volume Manager GUI
Accessibility Information
Supported Products
Data Services
File Systems
Oracle Solaris 10 on SPARC
Oracle Solaris 10 on x86
Memory Requirements
Oracle Solaris Operating System
Oracle VM Server for SPARC
Sun Management Center
Sun StorageTek Availability Suite
Volume Managers
Product Localization
Known Issues and Bugs
Administration
Resource Group Does Not Fail Over When Failover_mode Is Set to SOFT During a Public Interface Failure (7038727)
Unable to Register Resource Type SUNW.scalable_acfs_proxy in a Zone Cluster (7023590)
Oracle's SPARC T3-4 Fails During Reboot (6993321)
Removing the Last Node That Hosts a Zone Cluster Does Not Remove the Zone Cluster From the Cluster Configuration (6969605)
Missing /dev/rmt Causes Incorrect Reservation Usage When Policy Is pathcount (6920996)
The global_fencing Property Code is Broken When the Value is Changed to prefer3 (6879360)
Autodiscovery Does Not Work on LDoms With Hybrid I/O (6870171)
EMC SRDF and Hitachi TrueCopy Reject Switchover When Replicated Device-Group Status Will Cause Switchover and Switchback to Fail (6798901)
Configuring a Scalable Resource With the LB_STICKY_WILD Load Balancing Policy Fails With clsetup (6773401)
Removing Nodes from the Cluster Configuration Can Result in Node Panics (6735924)
If the Solaris Security Toolkit Is Configured on Cluster Nodes, scstat -i Gives an RPC Bind Failure Error(6727594)
More Validation Checks Needed When Combining DIDs (6605101)
Solaris Cluster Manager Fails to Come Up in a 16-Node Cluster (6594485)
Data Services
Resource Group Creation After Zone Cluster Reboot but Before RGM Reconfiguration Leads to Inconsistent State Within RGM (7041222)
Apache Tomcat Does Not Start Due to Missing Script (7022690)
SAP Web Application Server Primary Instance Not Able to Come Online on the Same Node After Killing the Dispatcher (7018400)
HAStoragePlus Resource Configured in Scalable Resource Group with Cluster File System Stays at "Starting" State Indefinitely (6960386)
Gateway Probe Will Ping Pong if Database Listener Is Not Reachable (6927071)
Scalable Applications Are Not Isolated Between Zone Clusters (6911363)
Running clnas add or clnas remove Command on Multiple Nodes at the Same Time Could Cause Problem (6791618)
clresourcegroup add-node Triggers an HAStoragePlus Resource to Become Faulted State (6547896)
Developer Environment
GDS Returns Incorrect Exit Status in STOP Method for Non-PMF Services (6831988)
Installation
The installer Deletes the Existing Package Corresponding to Ops Center Agent JavaDB Database. (6956479)
Localization
Result of System Requirements Checking Is Wrong (6495984)
Runtime
cldevicegroup Status Always Shows Multi-Owner Solaris Volume Manager Disk Sets Configured on vucmm Framework as "offline" (6962196)
ssm_start Fails Due to Unrelated IPMP Down (6938555)
Upgrade
Zones With ip-type=exclusive Cannot Host SUNW.LogicalHostname Resources After Upgrade (6702621)
Patches and Required Firmware Levels
Applying an Oracle Solaris Cluster 3.3 5/11 Core Patch
How to Apply the Oracle Solaris Cluster 3.3 5/11 Core Patch
Removing an Oracle Solaris Cluster 3.3 5/11 Core Patch
How to Remove an Oracle Solaris Cluster 3.3 5/11 Core Patch
Patch Management Tools
Patch for Cluster Support for Sun StorageTek 2530 Array
My Oracle Support
Oracle Solaris Cluster 3.3 5/11 Documentation Set
Documentation Addendum
Man Pages
clnasdevice(1CL)
clzonecluster(1CL)
SUNW.oracle_server(5)
SUNW.scalable_acfs_proxy(5)
A.  Documentation Appendix
Supported Products
This section describes the supported software and memory requirements for Oracle Solaris Cluster 3.3 5/11 software.
Data Services
Contact your Oracle sales representative for the complete list of supported data services (agents) and application versions.
File Systems
This section describes the supported file systems for Oracle Solaris Cluster 3.3 5/11 on the following platforms:
The following table describes the supported file systems for Oracle Solaris 10 on the SPARC platform.
File System
Additional Information
Oracle Solaris UFS
Oracle Solaris ZFS
Not supported for the /globaldevices file system
Veritas File System components that are delivered as part of Veritas Storage Foundation 5.1. Version 5.1 requires a minimum of SP1.
The following table describes the supported file systems for Oracle Solaris 10 on the x86 platform.
File System
Oracle Solaris UFS
Oracle Solaris ZFS
Memory Requirements
Oracle Solaris Cluster 3.3 5/11 software requires the following memory requirements for every cluster node:
Actual physical memory and hard drive requirements are determined by the applications that are installed. Consult the application's documentation or contact the application vendor to calculate additional memory and hard drive requirements.
Oracle Solaris Cluster 3.3 5/11 software and Quorum Server software requires one of the following versions of the Oracle Solaris OS:
Note - Oracle Solaris Cluster 3.3 5/11 software does not support multiple versions of Oracle Solaris software in the same running cluster.
This Oracle Solaris Cluster release supports Oracle VM Server for SPARC 2.0 and Sun Logical Domains (LDoms) 1.3 software.
This Oracle Solaris Cluster release supports Sun Management Center software versions 3.6.1 and 4.0.
This Oracle Solaris Cluster release supports Sun StorageTek Availability Suite 4.0 software. Support requires a minimum of patch 123246-07 for SPARC or 123247-07 for x86.
Volume Managers
This section describes the supported volume managers for Oracle Solaris Cluster 3.3 5/11 on the following platforms:
Volume Manager
Cluster Feature
Solaris Volume Manager for Sun Cluster
Veritas Volume Manager (VxVM) components that are delivered as part of Veritas Storage Foundation 5.1. Version 5.1 requires a minimum of SP1.
Not applicable - Oracle Solaris Cluster 3.3 5/11 software does not support the VxVM cluster feature
Volume Manager
Cluster Feature
Veritas Volume Manager components that are delivered as part of Veritas Storage Foundation 5.1. Version 5.1 requires a minimum of SP1.
Not applicable - Oracle Solaris Cluster 3.3 5/11 software does not support the VxVM cluster feature.
