Skip Navigation Links
Exit Print View
Oracle Solaris Cluster 3.3 Hardware Administration Manual     Oracle Solaris Cluster
search filter icon
search icon
Document Information
1.  Introduction to Oracle Solaris Cluster Hardware
2.  Installing and Configuring the Terminal Concentrator
3.  Installing Cluster Interconnect Hardware and Configuring VLANs
Interconnect Requirements and Restrictions
Cluster Interconnect and Routing
Cluster Interconnect Speed Requirements
Ethernet Switch Configuration When in the Cluster Interconnect
Requirements When Using Jumbo Frames
Requirements and Restrictions When Using InfiniBand in the Cluster Interconnect
Installing Ethernet or InfiniBand Cluster Interconnect Hardware
How to Install Ethernet or InfiniBand Transport Cables and Transport Junctions
Configuring VLANs as Private Interconnect Networks
4.  Maintaining Cluster Interconnect Hardware
5.  Installing and Maintaining Public Network Hardware
6.  Maintaining Platform Hardware
7.  Campus Clustering With Oracle Solaris Cluster Software
8.  Verifying Oracle Solaris Cluster Hardware Redundancy
The following table lists procedures for installing Ethernet or InfiniBand cluster interconnect hardware. Perform the procedures in the order that they are listed. This section contains the procedure for installing cluster hardware during an initial installation of a cluster, before you install Oracle Solaris Cluster software.
Table 3-1 Installing Ethernet Cluster Interconnect Hardware
For Instructions
Install the transport adapters.
The documentation that shipped with your nodes and host adapters
Install the transport cables.
If your cluster contains more than two nodes, install a transport junction (switch).
Use this procedure to install Ethernet or InfiniBand transport cables and transport junctions (switches).
  1. If not already installed, install transport adapters in your cluster nodes.
    See the documentation that shipped with your host adapters and node hardware.
  2. If necessary, install transport junctions and optionally configure the transport junctions' IP addresses.
    Note - (InfiniBand Only) If you install one InfiniBand adapter on a cluster node, two InfiniBand switches are required. Each of the two ports must be connected to a different InfiniBand switch.
    If two InfiniBand adapters are connected to a cluster node, connect only one port on each adapter to the InfiniBand switch. The second port of the adapter must remain disconnected. Do not connect ports of the two InfiniBand adapters to the same InfiniBand switch.
  3. Install the transport cables.
    • (Ethernet Only) As the following figure shows, a cluster with only two nodes can use a point-to-point connection, requiring no transport junctions.
      Figure 3-1 (Ethernet Only) Typical Two-Node Cluster Interconnect
      image:Illustration: shows two nodes that directly connect to form two interconnects.
      (Ethernet Only) For a point-to-point connection, you can use either UTP or fibre. With fibre, use a standard patch cable. A crossover cable is unnecessary. With UTP, see your network interface card documentation to determine whether you need a crossover cable.
      Note - (Ethernet Only) You can optionally use transport junctions in a two-node cluster. If you use a transport junction in a two-node cluster, you can more easily add additional nodes later. To ensure redundancy and availability, always use two transport junctions.
    • As the following figure shows, a cluster with more than two nodes requires transport junctions. These transport junctions are Ethernet or InfiniBand switches (customer-supplied).
      Figure 3-2 Typical Four-Node Cluster Interconnect
      image:Illustration: shows four nodes and two switches with one connection to each switch to form two interconnects.
See Also
To install and configure the Oracle Solaris Cluster software with the new interconnect, see Chapter 2, Installing Software on Global-Cluster Nodes, in Oracle Solaris Cluster Software Installation Guide.
(Ethernet Only) To configure jumbo frames on the interconnect, review the requirements in Requirements When Using Jumbo Frames and see the Sun GigaSwift documentation for instructions.
