Skip Navigation Links
Exit Print View
Oracle Solaris Cluster 3.3 Hardware Administration Manual     Oracle Solaris Cluster
search filter icon
search icon
Document Information
Preface
1.  Introduction to Oracle Solaris Cluster Hardware
2.  Installing and Configuring the Terminal Concentrator
3.  Installing Cluster Interconnect Hardware and Configuring VLANs
4.  Maintaining Cluster Interconnect Hardware
5.  Installing and Maintaining Public Network Hardware
6.  Maintaining Platform Hardware
7.  Campus Clustering With Oracle Solaris Cluster Software
8.  Verifying Oracle Solaris Cluster Hardware Redundancy
Testing Node Redundancy
How to Test Device Group Redundancy Using Resource Group Failover
Testing Cluster Interconnect Redundancy
How to Test Cluster Interconnects
Testing Public Network Redundancy
How to Test Public Network Redundancy
Index
This section provides the procedure for testing cluster interconnect redundancy.
Before You Begin
To perform this procedure, become superuser or assume a role that provides solaris.cluster.read and solaris.cluster.modify RBAC authorization.
  1. Disconnect one of the cluster transport cables from a node in the cluster.
    Messages similar to the following appear on the consoles of each node and are logged in the /var/adm/messages file.
    Nov  4 08:27:21 node1 genunix: WARNING: ce1: fault detected external to device; service degraded
    Nov  4 08:27:21 node1 genunix: WARNING: ce1: xcvr addr:0x01 - link down
    Nov  4 08:27:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being cleaned up
    Nov  4 08:27:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being drained
    Nov  4 08:27:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being constructed
    Nov  4 08:28:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 errors during initiation
    Nov  4 08:28:31 node1 genunix: WARNING: Path node1:ce1 - node1:ce0 initiation
    encountered errors, errno = 62.
      Remote node may be down or unreachable through this path.
  2. Verify that Oracle Solaris Cluster has registered that the interconnect is down.
    Use the following command to verify that the interconnect path displays as Faulted.
    # clinterconnect status
  3. Reconnect the cluster transport cable
    Nov  4 08:30:26 node1 genunix: NOTICE: ce1: fault cleared external to device; service available
    Nov  4 08:30:26 node1 genunix: NOTICE: ce1: xcvr addr:0x01 - link up 1000 Mbps full duplex
    Nov  4 08:30:26 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being initiated
    Nov  4 08:30:26 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 online
  4. Verify that Oracle Solaris Cluster has registered that the interconnect is up.
    Use the following command to verify that the interconnect path displays as Online.
  5. Repeat Step 1 through Step 4 on each cluster transport cable in the node.
  6. Repeat Step 1 through Step 5 on each node in the cluster.
