gss_create_empty_oid_set(3GSS)
gss_inquire_cred_by_mech(3GSS)
gss_inquire_mechs_for_name(3GSS)
gss_inquire_names_for_mech(3GSS)
gss_process_context_token(3GSS)
ldap_enable_translation(3LDAP)
ldap_get_entry_controls(3LDAP)
ldap_get_lang_values_len(3LDAP)
ldap_init_getfilter_buf(3LDAP)
ldap_init_searchprefs_buf(3LDAP)
ldap_init_templates_buf(3LDAP)
ldap_parse_extended_result(3LDAP)
ldap_parse_sasl_bind_result(3LDAP)
ldap_sasl_interactive_bind_s(3LDAP)
ldap_set_string_translators(3LDAP)
ldap_translate_from_t61(3LDAP)
rpc_gss_get_principal_name(3NSL)
rpc_gss_svc_max_data_length(3NSL)
sasl_auxprop_add_plugin(3SASL)
sasl_canonuser_add_plugin(3SASL)
sasl_client_plug_init_t(3SASL)
sasl_server_plug_init_t(3SASL)
sasl_server_userdb_checkpass_t(3SASL)
sasl_server_userdb_setpass_t(3SASL)
sdp_add_connection(3COMMPUTIL)
sdp_add_information(3COMMPUTIL)
sdp_delete_all_field(3COMMPUTIL)
sdp_delete_all_media_field(3COMMPUTIL)
sdp_delete_attribute(3COMMPUTIL)
sdp_find_attribute(3COMMPUTIL)
sdp_find_media_rtpmap(3COMMPUTIL)
sdp_session_to_str(3COMMPUTIL)
sip_delete_header_by_name(3SIP)
sip_disable_dialog_logging(3SIP)
sip_disable_trans_logging(3SIP)
sip_enable_dialog_logging(3SIP)
sip_enable_trans_logging(3SIP)
sip_get_contact_display_name(3SIP)
sip_get_content_sub_type(3SIP)
sip_get_dialog_local_contact_uri(3SIP)
sip_get_dialog_local_cseq(3SIP)
sip_get_dialog_local_tag(3SIP)
sip_get_dialog_local_uri(3SIP)
sip_get_dialog_remote_cseq(3SIP)
sip_get_dialog_remote_tag(3SIP)
sip_get_dialog_remote_target_uri(3SIP)
sip_get_dialog_remote_uri(3SIP)
sip_get_dialog_route_set(3SIP)
sip_get_from_display_name(3SIP)
sip_get_passertedid_display_name(3SIP)
sip_get_passertedid_uri_str(3SIP)
sip_get_ppreferredid_display_name(3SIP)
sip_get_ppreferredid_uri_str(3SIP)
sip_get_proxy_authen_param(3SIP)
sip_get_proxy_authen_scheme(3SIP)
sip_get_proxy_author_param(3SIP)
sip_get_proxy_author_scheme(3SIP)
sip_get_replyto_display_name(3SIP)
sip_get_retry_after_cmts(3SIP)
sip_get_retry_after_time(3SIP)
sip_get_route_display_name(3SIP)
sip_get_via_sent_by_host(3SIP)
sip_get_via_sent_by_port(3SIP)
sip_get_via_sent_protocol_name(3SIP)
sip_get_via_sent_protocol_version(3SIP)
sip_get_via_sent_transport(3SIP)
sip_get_www_authen_param(3SIP)
sip_get_www_authen_scheme(3SIP)
- convert an OID to a string
cc [ flag... ] file... -lgss [ library... ] #include <gssapi/gssapi.h> gss_oid_to_str(OM_uint32 *minor_status, const gss_OID oid, gss_buffer_toid_str);
Status code returned by underlying mechanism.
GSS-API OID structure to convert.
String to receive converted OID.
The gss_oid_to_str() function converts a GSS-API OID structure to a string. You can use the function to convert the name of a mechanism from an OID to a simple string. This function is a convenience function, as is its complementary function, gss_str_to_oid(3GSS).
If an OID must be created, use gss_create_empty_oid_set(3GSS) and gss_add_oid_set_member(3GSS) to create it. OIDs created in this way must be released with gss_release_oid_set(3GSS). However, it is strongly suggested that applications use the default GSS-API mechanism instead of creating an OID for a specific mechanism.
The gss_oid_to_str() function returns one of the following status codes:
A required input parameter could not be read.
A required output parameter could not be written.
Successful completion.
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
gss_add_oid_set_member(3GSS), gss_create_empty_oid_set(3GSS), gss_release_oid_set(3GSS), gss_str_to_oid(3GSS), attributes(5)
Solaris Security for Developers Guide
This function is included for compatibility only with programs using earlier versions of the GSS-API and should not be used for new programs. Other implementations of the GSS-API might not support this function, so portable programs should not rely on it. Sun might not continue to support this function.
