stat.h
, stat
- data returned by stat system call
Synopsis
#include <sys/types.h>
#include <sys/stat.h>
Description
The system calls stat(), lstat() and fstat() return data in a stat
structure, which is defined in <stat.h>.
The constants used in the st_mode field are also defined in this
file:
#define |
S_IFMT |
/* type of file */ |
#define |
S_IAMB |
/* access mode bits */ |
#define |
S_IFIFO |
/* fifo */ |
#define |
S_IFCHR |
/* character
special */ |
#define |
S_IFDIR |
/* directory */ |
#define |
S_IFNAM |
/* XENIX special named file */ |
#define |
S_INSEM |
/* XENIX semaphore
subtype of IFNAM */ |
#define |
S_INSHD |
/* XENIX shared data subtype of IFNAM */ |
#define |
S_IFBLK |
/* block
special */ |
#define |
S_IFREG |
/* regular */ |
#define |
S_IFLNK |
/* symbolic link */ |
#define |
S_IFSOCK |
/* socket */ |
#define |
S_IFDOOR |
/* door */ |
#define |
S_ISUID |
/* set
user id on execution */ |
#define |
S_ISGID |
/* set group id on execution */ |
#define |
S_ISVTX |
/* save
swapped text even after use */ |
#define |
S_IREAD |
/* read permission, owner */ |
#define |
S_IWRITE |
/* write permission,
owner */ |
#define |
S_IEXEC |
/* execute/search permission, owner */ |
#define |
S_ENFMT |
/* record locking enforcement flag */ |
#define |
S_IRWXU |
/* read,
write, execute: owner */ |
#define |
S_IRUSR |
/* read permission: owner */ |
#define |
S_IWUSR |
/* write permission: owner */ |
#define |
S_IXUSR |
execute permission: owner */ |
#define |
S_IRWXG |
/* read, write, execute: group */ |
#define |
S_IRGRP |
/* read permission: group
#define |
S_IWGRP |
/* write permission: group */ |
#define |
S_IXGRP |
/* execute permission: group */ |
#define |
S_IRWXO |
other */ |
#define |
S_IROTH |
/* read permission: other */ |
#define |
S_IWOTH |
/* write permission: other */ |
#define |
S_IXOTH |
other */ |
The following macros are for POSIX conformance (see standards(5)):
#define |
S_ISBLK(mode) |
block special file |
#define |
S_ISCHR(mode) |
character special
file |
#define |
S_ISDIR(mode) |
directory file |
#define |
S_ISFIFO(mode) |
pipe or fifo file |
#define |
S_ISREG(mode) |
regular file |
#define |
S_ISSOCK(mode) |
socket file |
The following symbolic constants are defined as distinct integer values outside of
the range [0, 999 999 999], for use with the futimens() and
utimensat() functions:
#define UTIME_NOW use the current time
@define UTIME_OMIT no time change
Attributes
Interface Stability |
Committed |
Standard |
See Also
futimens(2), stat(2), types.h(3HEAD), attributes(5), standards(5)
