C H A P T E R  11
Using Intelligent Platform Management Interface (IPMI)
This chapter describes the ILOM's Intelligent Platform Management Interface (IPMI) functionality and lists the supported IPMI commands.
This chapter includes the following sections:
11.1 About IPMI
The Intelligent Platform Management Interface (IPMI) is an open-standard hardware management interface specification that defines a specific way for embedded management subsystems to communicate. IPMI information is exchanged though baseboard management controllers (BMCs), which are located on IPMI-compliant hardware components. Using low-level hardware intelligence instead of the operating system has two main benefits:
Note - VMware EFX Server does not virtualize the Baseboard Management Controller (BMC) interface. That means that guest operating systems cannot load their BMC interface drivers. Also, IPMI utilities cannot use the BMC interface to interact with the Service Processor.
When run under a guest operating system, IPMI utilities must access the Service Processor over the network instead of using the BMC interface. Error messages that occur when the BMC interface driver fails to load can be safely ignored.
Your ILOM is IPMI v2.0 compliant. You can access IPMI functionality through the command line with the IPMItool utility either in-band or out-of-band. Additionally, you can generate an IPMI-specific trap from the web interface, or manage the server's IPMI functions from any external management solution that is IPMI v1.5 or v2.0 compliant. For more information about the IPMI v2.0 specification, go to:
http://www.intel.com/design/servers/ipmi/spec.htm#spec2.
Note - Your server includes a number of IPMI-compliant sensors that measure things such as voltages, temperature ranges, and security latches that detect when the enclosure is opened. For a complete list of sensors, see your platform supplement.
Caution - Do not use any interface other than the ILOM CLI or WebGUI to alter the state or configuration of any sensor or LED. Doing so could void your warranty.
11.1.1 IPMItool
IPMItool is a simple command-line interface that is useful for managing IPMI-enabled devices. You can use this utility to perform IPMI functions with a kernel device driver or over a LAN interface. IPMItool enables you to manage system field-replaceable units (FRUs), monitor system health, and monitor and manage the system environment, independent of the operating system.
You can download IPMItool from http://ipmitool.sourceforge.net/. Also, a copy of IMPItool and its related documentation is provided on your server Tools and Drivers CD.
When IPMItool is installed, it includes a man page. To view it, type:
man ipmitool
11.2 Supported IPMI 2.0 Commands
TABLE 11-1 lists the supported IPMI 2.0 commands.
Note - When a hard drive is unconfigured in the host OS, the command ipmitool ... sdr elist shows it as "Drive Present, Hot Spare." This means it is inserted but safe to remove.
For details on individual commands, see the Intelligent Platform Management Interface Design Specification, v2.0. A copy is available at:
TABLE 11-1 Supported IPMI 2.0 Commands
General Commands
Get Device ID
Cold Reset
Warm Reset
Get Self Test Results
Set/Get ACPI Power State
Reset/Set/Get Watchdog Timer
Set/Get BMC Global Enables
Clear/Get Message Flags
Enable Message Channel Receive
Get/Send Message
Read Event Message Buffer
Get Channel Authentication Capabilities
Get Session Challenge
Activate/Close Session
Set Session Privilege Level
Get Session Info
Set/Get Channel Access
Get Channel Info Command
Set/Get User Access Command
Set/Get User Name
Set User Password Command
Master Write-Read
Set/Get Chassis Capabilities
Get Chassis Status
Chassis Control
Chassis Identify
Set Power Restore Policy
Get System Restart Cause
Set/Get System Boot Options
Set/Get Event Receiver IPMI
System Interface Support
KCS
BT
RCMP
  • Multiple Payloads
  • Enhanced Authentication
  • Encryption
PEF and Alerting Commands
Get PEF Capabilities
Arm PEF Postpone Timer
Set/Get PEF Configuration Parameters
Set/Get Last Processed Event ID
Alert Immediate
PET Acknowledge
Sensor Device Commands
Get Sensor Reading Factors
Set/Get Sensor Hysteresis
Set/Get Sensor Threshold
Set/Get Sensor Event Enable
Get Sensor Reading
Set Sensor Type
FRU Device Commands
Get FRU Inventory Area Info
Read/Write FRU Data SDR Device Commands
Get SDR Repository Info
Get SDR Repository Allocation
Reserve SDR Repository
Get/Add SDR
Partial Add SDR
Clear SDR Repository
Get SDR Repository Time
Enter/Exit SDR Repository Update
Run Initialization Agent
SEL Device Commands
Get SEL Info
Get SEL Allocation Info
Reserve SEL
Get/Add SEL Entry
Clear SEL
Set/Get SEL Time
LAN Device Commands
Get LAN Configuration Parameters
Suspend BMC ARPs
Serial/Modem Device Commands
Set/Get Serial Modem Configuration
Set Serial Modem MUX
Get TAP Response Codes
Serial/Modem Connection Active
Callback
Set/Get User Callback Options
Event Commands
Get Event Count
Set/Get Event Destination
Set/Get Event Reception State
Send ICMB Event Message
