Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageColorRGB2XYZ(mlib_image *dst, const mlib_image *src);
The mlib_ImageColorRGB2XYZ() function performs a color space conversion from ITU-R Rec.708 RGB with D64 white point to CIE XYZ.
The source and destination images must be three-channel images.
It uses the following equation:
|X| |cmat[0] cmat[1] cmat[2]| |R| |Y| = |cmat[3] cmat[4] cmat[5]| * |G| |Z| |cmat[6] cmat[7] cmat[8]| |B|
where
cmat[] = { 0.412453, 0.357580, 0.180423, 0.212671, 0.715160, 0.072169, 0.019334, 0.119193, 0.950227 }; src[x][y] = { R, G, B }; dst[x][y] = { X, Y, Z };
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageColorConvert1(3MLIB), mlib_ImageColorConvert1_Fp(3MLIB), mlib_ImageColorRGB2XYZ_Fp(3MLIB), mlib_ImageColorXYZ2RGB(3MLIB), mlib_ImageColorXYZ2RGB_Fp(3MLIB), mlib_ImageColorYCC2RGB(3MLIB), mlib_ImageColorYCC2RGB_Fp(3MLIB), attributes(5)
