Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageColorRGB2YCC(mlib_image *dst, const mlib_image *src);
The mlib_ImageColorRGB2YCC() function performs a color space conversion from computer R'G'B' to ITU-R Rec.601 Y'CbCr.
The source and destination images must be three-channel images.
It uses the following equation:
|Y'| |cmat[0] cmat[1] cmat[2]| |R'| |offset[0]| |Cb| = |cmat[3] cmat[4] cmat[5]| * |G'| + |offset[1]| |Cr| |cmat[6] cmat[7] cmat[8]| |B'| |offset[2]|
where
cmat[] = { 65.738/256, 129.057/256, 25.064/256, -37.945/256, -74.494/256, 112.439/256, 112.439/256, -94.154/256, -18.285/256 }; offset[] = { 16, 128, 128 }; src[x][y] = { R', G', B' }; dst[x][y] = { Y', Cb, Cr };
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageColorConvert2(3MLIB), mlib_ImageColorConvert2_Fp(3MLIB), mlib_ImageColorRGB2YCC_Fp(3MLIB), mlib_ImageColorXYZ2RGB(3MLIB), mlib_ImageColorXYZ2RGB_Fp(3MLIB), mlib_ImageColorYCC2RGB(3MLIB), mlib_ImageColorYCC2RGB_Fp(3MLIB), attributes(5)
