Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageZoomIn2X(mlib_image *dst, const mlib_image *src, mlib_filter filter, mlib_edge edge);
The mlib_ImageZoomIn2X() function enlarges the source image by a factor of two. It uses the interpolation method as described by the resampling filter.
The center of the upper-left corner pixel of an image is located at (0.5, 0.5).
The width and height of the destination image can be different from those of the source image.
The center of the source image is mapped onto the center of the destination image.
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Type of resampling filter. It can be one of the following:
MLIB_NEAREST MLIB_BILINEAR MLIB_BICUBIC MLIB_BICUBIC2
Type of edge condition. It can be one of the following:
MLIB_EDGE_DST_NO_WRITE MLIB_EDGE_DST_FILL_ZERO MLIB_EDGE_OP_NEAREST MLIB_EDGE_SRC_EXTEND MLIB_EDGE_SRC_PADDED
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_ImageZoom(3MLIB), mlib_ImageZoom_Fp(3MLIB), mlib_ImageZoomIn2X_Fp(3MLIB), mlib_ImageZoomIn2XIndex(3MLIB), mlib_ImageZoomIndex(3MLIB), mlib_ImageZoomOut2X(3MLIB), mlib_ImageZoomOut2X_Fp(3MLIB), mlib_ImageZoomOut2XIndex(3MLIB), attributes(5)
