The dlcosmk marker module marks a forwarding behavior in the MAC header of a datagram. You can use dlcosmk only on an IPQoS system with a VLAN interface.
dlcosmk adds four bytes, which are known as the VLAN tag, to the MAC header. The VLAN tag includes a 3-bit user-priority value, which is defined by the IEEE 801.D standard. Diffserv-aware switches that understand VLAN can read the user-priority field in a datagram. The 801.D user priority values implement the class-of-service (CoS) marks, which are well known and understood by commercial switches.
You can use the user-priority values in the dlcosmk marker action by defining the class of service marks that are listed in the next table.
Table 31–3 801.D User-Priority Values
Class of Service |
Definition |
0 |
Best effort |
1 |
Background |
2 |
Spare |
3 |
Excellent effort |
4 |
Controlled load |
5 |
Video less than 100ms latency |
6 |
Video less than 10ms latency |
7 |
Network control |
For more information on dlcosmk, refer to the dlcosmk(7ipp) man page.
This section introduces a simple network scenario that shows how to implement IPQoS on systems with VLAN devices. The scenario includes two IPQoS systems, machine1 and machine2, that are connected by a switch. The VLAN device on machine1 has the IP address 10.10.8.1. The VLAN device on machine2 has the IP address 10.10.8.3.
The following IPQoS configuration file for machine1 shows a simple solution for marking traffic through the switch to machine2.
fmt_version 1.0 action { module ipgpc name ipgpc.classify filter { name myfilter2 daddr 10.10.8.3 class myclass } class { name myclass next_action mark4 } } action { name mark4 module dlcosmk params { cos 4 next_action continue global_stats true } }
In this configuration, all traffic from machine1 that is destined for the VLAN device on machine2 is passed to the dlcosmk marker. The mark4 marker action instructs dlcosmk to add a VLAN mark to datagrams of class myclass with a CoS of 4. The user-priority value of 4 indicates that the switch between the two machines should give controlled load forwarding to myclass traffic flows from machine1.
