This command creates an application profile.
You use an application profile to deploy an application on the servers.
N1 Grid Engine (N1GE) is the only application that can be provisioned with this release of N1 System Manager.
Create an N1GE application profile:
create applicationprofile applicationprofile application application type n1ge [N1GE-Attributes] |
application – The name of an application to install.
applicationprofile – A unique name for the application profile.
N1GE ATTRIBUTES
adminhomedir adminhomedir – The home directory of the N1GE admin user. Default value is /gridware/sge.
adminuid adminuid – The UID of the N1GE admin user. Default value is 218.
adminusername adminusername – The user name of the N1GE admin user. Default value is sgeadmin.
execdport execdport – The TCP port to use for the N1GE execd daemon. Default value is 837.
instversion instversion – The version of N1GE that will be deployed on the compute and submit hosts. There is no default value.
lnxnfsmtopts lnxnfsmtopts – The options used when mounting the “common” directory onto a Linux compute or submit host. The value in this field is inserted into the Linux /etc/fstab file on each host as: nfsservername:nfsmountpoint nfsmountpoint nfs lnxnfsmtopts 0 0. Default value is intr,softload. This value cannot contain spaces.
loadcritical loadcritical – Use this parameter to specify the load critical threshold. If this threshold is exceeded, a load critical alert appears in the Monitor. Similar to the Load Warning parameter, you set this parameter in terms of the system load scaled by number of CPUs. Default value is 3.00.
loadwarning loadwarning – Use this parameter to specify the load warning threshold. If this threshold is exceeded, a load warning alert appears in the Monitor. The value is in terms of system load, as reported by the OS, divided by the number of CPUs. Default value is 1.00.
masterport masterport – The TCP port to use for the N1GE qmaster daemon. Default value is 836.
maxpendtime maxpendtime – Use this parameter to specify the amount of time that a job spends pending after which a Job Pending alert appears in the Monitor. You set the value in hours. Default value is 24.
memcritical memcritical – Use this parameter to set the memory critical threshold. If the value drops below this threshold, a memory critical alert appears in the Monitor. You set the value in terms of megabytes of free virtual memory. Default value is 10.
memwarning memwarning – Use this parameter to set the memory warning threshold. If the value drops below this threshold, a memory warning alert appears in the Monitor. You set the parameter value in terms of megabytes of free virtual memory. Default value is 100.
nfsmountpoint nfsmountpoint – The directory that is mounted from the NFS server for the N1GE “common” directory. When deploying the master host using N1GE, this value is set automatically to sgeroot/sgecell/common. Once you deploy the master host, you cannot edit this value and it remains in effect for all further deployments of compute and submit hosts. You can edit this setting again only if you uninstall the master host. Default value is /gridware/sge/default/common.
nfsservername nfsservername – The name of the NFS server from which all compute and submit hosts will mount the N1GE “common” directory. When you deploy the master host using N1GE, this parameter is set automatically to the master host. Once you deploy the master host, you cannot edit this value and it remains in effect for all further deployments of compute and submit hosts. You can edit this setting again only if you uninstall the master host. There is no default value.
proxyhost proxyhost – Indicates the host on which monitoring commands are executed. If the master host has been previously deployed using N1GE, then the proxy host is set to this host and cannot be changed until the master is uninstalled. The host you chose must be an N1GE admin host; otherwise, installation and uninstallation of other hosts, as well as monitoring, could fail. There is no default value.
sgecell sgecell – The N1GE cell name used for the deployment. Default value is default.
sgeroot sgeroot – The root directory under which the N1GE files will be installed. The files will be installed on all hosts in this directory. Default value is /gridware/sge.
solnfsmtopts solnfsmtopts – The options used when mounting the “common” directory onto a Solaris compute or submit host. The value in this field is inserted into the Solaris /etc/vfstab file on each host as: nfsservername:nfsmountpoint nfsmountpoint nfs -yes solnfsmtopts. There is no default value. This value cannot contain spaces.
