Sun Management Center 3.5 Performance Reporting Manager User's Guide
Line Breaks
The legend of a report lists all the data properties contained in the report. You can insert line breaks in the legend to enhance appearance. You use HTML commands to do this. Inserting a line break by using an escape character such as \n does not work as this character is not recognized.
To Insert a Line Break
To insert a line break in the report's legend, follow these steps:
  1. From the report window, choose Edit, then select Customize Graph.
    The Customize Graph dialog box appears.
  2. Select the Line Attributes folder.
    The view changes to show the options already selected.
  3. From the drop-down menu in the Selected Line field, select the name of the data property you want to edit.
    The name of the data property selected in the Selected Line field appears in the Text field. You edit this field to insert the line break. The HTML tag <p> is used to create the line break.
  4. Insert the line break by typing:
    <html> data_property_name <p> <\html>
    The line break appears wherever the <p> tag is inserted. You can place this tag anywhere in the full data property name. For example:
    <html>% CPU <p> Kernel Time(0)<\html>
    results in the line break appearing after % CPU in the report legend.
  5. Click OK.
    The line break appears in the report legend. Repeat this procedure for as many line breaks as you want to insert.
