Sun Management Center 3.5 Performance Reporting Manager User's Guide
Data Properties Logging
You can either enable the logging of a single data property, or you can enable the logging of many data properties on many hosts at the same time. The second method is called group logging, and is done by using the Manage Jobs features of Sun Management Center 3.5. For more information about group logging, see Group Logging.
You must enable the logging of a single data property from the Sun Management Center 3.5 console.
To Enable Logging of a Single Data Property
  1. From the Sun Management Center 3.5 console window, select the host name from the hierarchy.
    The Details window appears.
  2. From the left pane, select the desired module from the hierarchy view.
    The hierarchy view expands to reveal table names underneath.
  3. Double-click the desired table name.
    A table appears in the right pane. Each row contains a data property. More than one table can appear, depending upon the module.
  4. Highlight the row containing the desired data property, and press mouse button 3.
    A pop-up menu appears.
  5. Select Attribute Editor.
    The Attribute Editor dialog box appears.
  6. Select the History tab.
  7. Place a check in the Save History as Disk File box.
  8. From the File Type drop-down menu, select Circular File.
  9. Click OK to close.
    Data logging is now enabled on the data property.
