Sun Management Center 3.5 Performance Reporting Manager User's Guide
Custom System Configuration Report Fields
The report template for creating a custom system configuration report has two fields that are found in this type of report:
The other possible fields available for this type of report are as described in Common Custom Report Fields.
Level of Detail
Use the Level of Detail field to determine the amount of detail wanted in the report. Accept either the default (Detailed) or select Summary. If you select Summary, the following information is returned:
Filter
The Filter field is optional. Click Set Filter to select the desired filter options from the Filter dialog box. Use the drop-down menus to build an expression that creates the report filter wanted. The filtering options are case sensitive. For more information, see Filtering Reports.
