Sun Management Center 3.5 Performance Reporting Manager User's Guide
Customizing Line Graph Reports
Once you have run a report in line graph format, you can further customize the appearance of the report. From the Edit menu, choose Customize Graph. The options are the same as when completing a new custom report template. The difference is that the customizing options you select after running a report apply only to that report. You cannot save the changes, but you can post the customized report to a Sun Management Center web server for viewing or printing.
For more information, see Customizing the Appearance of Reports.
