Before you configure the Solaris Resource Manager product in a Sun Cluster environment, you must decide how you want to control and track resources across switchovers or failovers. If you configure all cluster nodes identically, usage limits will be enforced identically on primary and backup nodes.
While the configuration parameters need not be identical for all applications in the configuration files on all nodes, all applications must at least be represented in the configuration files on all potential masters of that application. For example, if Application 1 is mastered by phys-schost-1 but could potentially be switched or failed-over to phys-schost-2 or phys-schost-3, then Application 1 must be included in the configuration files on all three nodes (phys-schost-1, phys-schost-2, and phys-schost-3).
Solaris Resource Manager is very flexible with regard to configuration of usage and accrual parameters, and few restrictions are imposed by Sun Cluster. Configuration choices depend on the needs of the site. Consider the general guidelines in the following sections before configuring your systems.
When using the Solaris Resource Manager product with Sun Cluster, you should configure memory limits appropriately to prevent unnecessary failover of applications and a ping-pong effect of applications. In general:
Do not set memory limits too low.
When an application reaches its memory limit, it might fail over. This is especially important for database applications, when reaching a virtual memory limit can have unexpected consequences.
Do not set memory limits identically on primary and backup nodes.
Identical limits can cause a ping-pong effect when an application hits its memory limit and fails over to a backup node with an identical memory limit. Set the memory limit slightly higher on the backup node. The applications, resources, and preferences at the site determine how much higher the limit is set. The difference in memory limits helps prevent the ping-pong scenario and gives you a period of time in which to adjust the parameters as necessary.
Do use the Solaris Resource Manager memory limits for coarse-grained problem scenario load-balancing.
For example, you can use memory limits to prevent an errant application from consuming excess resources.
Several Solaris Resource Manager parameters are used for keeping track of system resource usage accrual: CPU shares, number of logins, and connect-time. However, in the case of switchover or failover, usage accrual data (CPU usage, number of logins, and connect-time) will restart at zero by default on the new master for all applications that were switched or failed over. Accrual data is not transferred dynamically across nodes.
To avoid invalidating the accuracy of the Solaris Resource Manager usage accrual reporting feature, you can create scripts to gather accrual information from the cluster nodes. Because an application might run on any of its potential masters during an accrual period, the scripts should gather accrual information from all possible masters of a given application. For more information, see Chapter 9, Usage Data.
