On a two-node cluster with three applications, you can configure it such that one physical host (phys-schost-1) is the default master of one application and the second physical host (phys-schost-2) is the default master for the remaining two applications. Assume the following example limits database file on every node. The limits database file does not change when a failover or switchover occurs.
# limadm set cpu.shares=50 App-1 # limadm set cpu.shares=30 App-2 # limadm set cpu.shares=20 App-3 ... |
When the cluster is running normally, Application 1 is allocated 50 shares on its default master, phys-schost-1. This is equivalent to 100 percent of CPU resources because it is the only application demanding CPU resources on that node. Applications 2 and 3 are allocated 30 and 20 shares, respectively, on their default master, phys-schost-2. Application 2 would receive 60 percent and Application 3 would receive 40 percent of CPU resources during normal operation.
If a failover or switchover occurs and Application 1 is switched over to phys-schost-2, the shares for all three applications remain the same, but the percentages of CPU resources are re-allocated according to the limits database file.
Application 1, with 50 shares, receives 50 percent of CPU.
Application 2, with 30 shares, receives 30 percent of CPU.
Application 3, with 20 shares, receives 20 percent of CPU.
The following diagram illustrates the normal and failover operations of this configuration.
