Solaris Resource Manager 1.3 System Administration Guide
Multi-User Startup Configuration
During a normal system boot, when the system changes from single-user to multi-user mode, a Solaris Resource Manager initialization script (see Appendix A, Solaris Resource Manager Code Examples) is run to set various Solaris Resource Manager parameters. Details of what this script does are given in Chapter 4, Boot Procedure.
If the initialization script itself (/etc/init.d/init.srm) is modified, copies of both the original and modified versions should be kept separately. Applying Solaris Resource Manager updates will not necessarily preserve existing initialization scripts.
