The liminfo(1SRM) command uses the same suffixes when reporting as limadm uses for input (see above). Normally, liminfo converts values into appropriate scaled formats to be printed, but the -r option can be used to cause liminfo to print values in their raw (unscaled) form. For example, memory is normally scaled to a suitable unit, such as megabytes (for example, '102 MB'), but specifying the -r option causes it to be printed in bytes (for example, 106954752 bytes).
