Solaris Resource Manager 1.3 System Administration Guide
Calculation of Allocated Share
Using the previous figure as an example, nodes A, C, and N currently have processes attached to them. At the topmost level, the CPU would only need to be shared between A and M since there are no processes for W or any member of scheduling group W. The ratio of shares between A and M is 3:1, so the allocated share at the topmost level would be 75 percent to group A, and 25 percent to group M.
The 75 percent allocated to group A would then be shared between its active users (A and C), in the ratio of their shares within group A (that is, 1:2). Note that the myshares attribute is used when determining A's shares with respect to its children. User A would therefore get one third of the group's allocated share, and C would get the remaining two thirds. The whole of the allocation for group M would go to lnode N since it is the only lnode with processes.
The overall distribution of allocated share of available CPU would therefore be 0.25 for A, 0.5 for C, and 0.25 for N.
Further suppose that the A, C, and N processes are all continually demanding CPU and that the system has at most two CPUs. In this case, Solaris Resource Manager will schedule them so that the individual processes receive these percentages of total available CPU:
The rate of progress of the individual processes is controlled so that the target for each lnode is met. On a system with more than two CPUs and only these six runnable processes, the C process will be unable to consume the 50 percent entitlement, and the residue is shared in proportion between A and N.
