Solaris Resource Manager 1.3 System Administration Guide
Producing Reports With rcapstat
The examples in this section show you how to use rcapstat to monitor the resource utilization of collections of processes that have physical memory caps defined.
Using rcapstat to Report Cap and Lnode Information
Caps are defined for two lnodes associated with two users. user1 has a cap of 50 megabytes, and user2 has a cap of 10 megabytes.
The following command produces reports at 5-second sampling intervals. A report will be issued five times, once after each sample.
usermachine% rcapstat 5 5
    id lnode   nproc    vm   rss   cap    at avgat    pg avgpg
112270 user1      24  123M   35M   50M   50M    0K 3312K    0K
 78194 user2       1 2368K 1856K   10M    0K    0K    0K    0K
112270 user1      24  123M   35M   50M    0K    0K    0K    0K
 78194 user2       1 2368K 1928K   10M    0K    0K    0K    0K
The first three lines of output constitute the first report, which contains the cap and lnode information for the two lnodes, and paging statistics since rcapd was started. The at and pg columns are a number greater than zero for user1 and zero for user2, which indicates that at some time in the daemon's history, user1 exceeded its cap but user2 did not.
The subsequent reports contain paging statistics since the prior intervals, but show no significant activity.
Lowering the Cap of an Lnode
The limadm(1MSRM) command can be used to lower the memory cap of an lnode, which makes the cap more restrictive. rcapd will enforce the new cap after the next configuration interval (see rcapadm(1MSRM)). A signal can also be sent, which causes rcapd to enforce the new cap immediately.
admin# limadm set rss.limit=30M user1
admin# pkill -HUP rcapd
admin# rcapstat 5 5
112270 user1      24  123M   35M   30M   50M    0K 3312K    0K
112270 user1      24  123M   36M   30M   52M   52M  632K  632K
 78194 user2       1 2368K 2096K   10M    0K    0K    0K    0K
112270 user1      24  123M   33M   30M   57M   52M  816K  632K
 78194 user2       1 2368K 1968K   10M    0K    0K    0K    0K
112270 user1      24  123M   27M   30M 4792K 4792K   40K   40K
 78194 user2       1 2368K 1144K   10M    0K    0K    0K    0K
112270 user1      24  123M   27M   30M    0K    0K    0K    0K
When the cap was lowered to 30 megabytes from 50 megabytes, rcapd responded by attempting to page out the 6-megabyte amount of resident memory above the cap value. The goal was reached; it was exceeded by a small amount.
Using rcapstat to Monitor the RSS of a Project
user1machine% rcapstat 5 5
id     project   nproc    vm   rss   cap    at avgat    pg avgpg
376565 user1        57  209M   46M   10M  440M  220M 5528K 2764K
376565 user1        57  209M   44M   10M  394M  131M 4912K 1637K
376565 user1        56  207M   43M   10M  440M  147M 6048K 2016K
376565 user1        56  207M   42M   10M  522M  174M 4368K 1456K
376565 user1        56  207M   44M   10M  482M  161M 3376K 1125K
In this example, the project user1 has an RSS in excess of its physical memory cap. The nonzero values in the pg column indicate that rcapd is consistently paging out memory as it attempts to meet the cap by lowering the physical memory utilization of the project's processes. However, rcapd is unsuccessful, as indicated by the varying rss values that do not show a corresponding decrease. This means that the application's resident memory is being actively used, forcing rcapd to affect the working set. Under this condition, the system will continue to experience high page fault rates, and associated I/O, until the working set size is reduced, the cap is raised, or the application changes its memory access pattern.
Determining the Working Set Size of a Project
The following example is a continuation of the previous example, and it uses the same project.
example% rcapstat 5 5
376565 user1         56  207M   44M   10M  381M  191M   15M 7924K
376565 user1         56  207M   46M   10M  479M  160M 2696K  898K
376565 user1         56  207M   46M   10M  424M  141M 7280K 2426K
376565 user1         56  207M   43M   10M  401M  201M 4808K 2404K
376565 user1         56  207M   43M   10M  456M  152M 4800K 1600K
376565 user1         56  207M   44M   10M  486M  162M 4064K 1354K
376565 user1         56  207M   52M  100M  191M   95M 1944K  972K
376565 user1         56  207M   55M  100M    0K    0K    0K    0K
376565 user1         56  207M   56M  100M    0K    0K    0K    0K
By inhibiting cap enforcement, either by raising the cap of a project or by changing the minimum cap enforcement memory pressure value (see rcapadm(1MSRM)), the resident set can become the working set. The rss column might stabilize to show the project working set size, as shown in this example. This is the minimum cap value that will allow the project's processes to operate without perpetually incurring page faults.
