Solaris Resource Manager 1.3 System Administration Guide
Lowering the Cap of an Lnode
The limadm(1MSRM) command can be used to lower the memory cap of an lnode, which makes the cap more restrictive. rcapd will enforce the new cap after the next configuration interval (see rcapadm(1MSRM)). A signal can also be sent, which causes rcapd to enforce the new cap immediately.
admin# limadm set rss.limit=30M user1
admin# pkill -HUP rcapd
The following command produces reports at 5-second sampling intervals. A report will be issued five times, once after each sample.
admin# rcapstat 5 5
    id lnode   nproc    vm   rss   cap    at avgat    pg avgpg
112270 user1      24  123M   35M   30M   50M    0K 3312K    0K
 78194 user2       1 2368K 1856K   10M    0K    0K    0K    0K
112270 user1      24  123M   36M   30M   52M   52M  632K  632K
 78194 user2       1 2368K 2096K   10M    0K    0K    0K    0K
112270 user1      24  123M   33M   30M   57M   52M  816K  632K
 78194 user2       1 2368K 1968K   10M    0K    0K    0K    0K
112270 user1      24  123M   27M   30M 4792K 4792K   40K   40K
 78194 user2       1 2368K 1144K   10M    0K    0K    0K    0K
112270 user1      24  123M   27M   30M    0K    0K    0K    0K
When the cap was lowered to 30 megabytes from 50 megabytes, rcapd responded by attempting to page out the 6-megabyte amount of resident memory above the cap value. The goal was reached; it was exceeded by a small amount.
