You must install the Sun Web Console software only in the default location.
Become superuser by typing:
% su - |
If you have the Tomcat server already installed, check the version by typing:
# pkginfo -l SUNWtcatu |
The version that is included with the Sun Web Console software is identified as 11.9.0,REV=2002.03.02.00.35.
If your version starts with 11.8.0 or lower, remove the Tomcat server by typing:
# pkgrm SUNWtcatu |
The correct version is later installed as part of this procedure.
Insert the Sun Management Center 3.5 Update 1b CD 2 of 2.
Change directories to where the Sun Web Console software is located by typing:
# cd /cdrom/cdrom0/image/Lockhart2.2.3 |
Set the JAVA_HOME variable. For example, in the C shell, type:
# setenv JAVA_HOME /usr/j2se/bin |
Install the software by typing:
# ./setup |
If the system has J2SE version 1.4.2 software installed, the installer automatically installs the Sun Web Console software. Wait until the installation is completed.
If the system has a J2SE version lower than 1.4.2 installed, J2SE version 1.4.2 software is automatically installed along with the Sun Web Console software. Wait until the installation is completed.
At the end of installation, the following message is displayed:
Installation complete. Server not started! No management applications registered |
This is a valid message.
Enable the automatic startup of Sun Web Console at reboot by typing:
# /usr/sbin/smcwebserver enable |
Continue with the installation of the Sun Management Center 3.5 Update 1b software.
For more information, see the following:
