NAME | Synopsis | Description | Operands | Examples | Exit Status | See Also
export [ name=value [ name=value]*]
The export command marks a variable name for automatic export to the environment of subsequent commands. All subsequent commands use the variable name value as specified unless you unset them or exit multimode. If only the variable name is specified, the current value of that variable name is displayed. If the export command is used without any arguments, a list of all the exported variables and their values is displayed. Exported shell environment variables set prior to invoking the asadmin utility are imported automatically and set as exported variables within asadmin. Unexported environment variables cannot be read by the asadmin utility.
variable name and value for automatic export to the environment to be used by subsequent commands.
asadmin> export AS_ADMIN_USER = admin AS_ADMIN_HOST = bluestar AS_ADMIN_PREFIX = server1.jms-service AS_ADMIN_PORT = 8000 |
asadmin> export AS_ADMIN_HOST=bluestar In this case, the AS_ADMIN_HOST environment variable has been set to bluestar. |
asadmin> export AS_ADMIN_HOST=bluestar AS_ADMIN_PORT=8000 AS_ADMIN_USER=admin AS_ADMIN_PREFIX=server1.jms-service In this case, the environment variables have been set to: host is set to bluestar port is set to 8000 administrator user is set to admin prefix is set to server1.jms-service |
